I agree on a bigger button but not mid screen.
Suggesting to forum moderators: create subfolders or something for these threads that have 50+ pages (for this one things like Navigation, Car Settings, Entertainment, Battery Status, etc). Nobody has the patience to read through that many pages to avoid making duplicate posts/suggestions...
Excuse if this is a repeat I haven't looked through all 62 pages.
GPS enabled homelink activation.
I would like it as an option for gated community receivers.
Automatic signal generation to open the gate as the car approaches using GPS location.
Using the touchscreen is tedious with the drop down boxes.
Of course it would have to be optional because you wouldn't want that on a garage door.
Basically, when my kid uses it (ie he takes it without my permission), I want it to be a miserable experience for him. I will handle his misery when he returns, but I'd love Tesla to mange his misery during the joy ride.
Locking the car into a Driver Profile with limits on max torque, max speed, and certain app restrictions sounds a lot like valet mode. How to force a certain driver to use a certain profile, without also forcing other (regular) drivers to use a password or something to access their profile and so the restricted driver cannot access it, is a lot tougher.
If you are actively braking, and then clip accelerator, there is NOT an accelerator cutoff, you get juice and braking at same time. If you accelerate first, then simultaneously brake, there is accelerator cutoff.
GPS enabled Homelink activation
I agree. In case there is some reason (jack rabbit start?) cutting power with both pedals are depressed could only happen above some threshold speed like 15mph. There is NO good reason to have both pedals pressed above that speed.... but it happens accidentally with larger feet, winter boots, wet shoe that slips, etc. I think it would be a win-win software improvement.David Noland suggests Model S pedal placement is a safety hazard - Page 12
As explained, if you press the brake and accelerator together, a warning chime and message is shown. However, the order matters:
Now we have hill assist, there is no need for this behavior.
The firmware should be changed so that accelerator is cutoff if both brake and accelerator are pressed, no matter which is pressed first.
