I'll definitely check this, but in my case I hear the sound even when the sound system is on mute! How would cell phone interference do that?
The speaker wires act as antennae.
More likely, it's being picked up by the wiring before the amplifier. Just because the audio is muted, doesn't mean the amplifier isn't running or the gain is way down.The speaker wires act as antennae.
Neither Telus nor Bell run a GSM network, hence no EDGE, no interference.
An aside. If you are looking for data speed, you want LTE. With a strong signal I've experienced download speeds as high as 106 Mbps in BC. In Vancouver I've seen 53Mbps, both down AND UP! Makes me wonder how much longer I'll bother with a wire based ISP.
Not sure. With the exception of the CDMA version of the iPhone 4 (A1349), I think that every iPhone is EDGE capable. If you are roaming on a non-CDMA capable network (with a EDGE capable iPhone), I expect that the iPhone will drop back to EDGE from time to time, and as neither Bell nor Telus run a GSM network, I would think that the only time your iPhone would drop back to EDGE is if it is roaming. Again, not sure....I am on an iPhone running on the Bell network. I have only noticed the noises when I was in a low signal area. Does the iPhone try EDGE regardless of carrier if signal is low or non-existent?
This just happened on my car last week. They are going to valet me a loaner on Tuesday and get me all fixed up.Last night drove a friend home to Saratoga, CA and as we drove away, noticed a rear window open. When I tried to close it, I heard a crunch! Drove a half mile to dinner. Had to slide the window up manually. Called Tesla Service and left a message since it was late. Tesla Service called just after 7:00am! The car is in the shop to replace both rear window actuators. I had the same issue with the other window over a year ago! They said that the actuators have since been redesigned and shouldn't have any issue again.
Every once in a while when I lock my doors, the passenger side door pops open! Has anyone seen this happen before?
I had this happen a long time ago. With the new handles I haven't seen the issue since. That was over a year ago. How old is your car?
They just contacted me and I'll be going to the service center on Tuesday. I should correct, that it happens when I Unlock the door not when I lock it. It only happens once in a while but I may as well have them take a look. It sounds like they'll probably give me some of the newer handles. Were there any improvements made on the new handles? Why did they change them? Was it because they were popping open, or something else?
"It is important to note that GSM is a second-generation (2G) standard employing Time-Division Multiple-Access (TDMA) spectrum-sharing, issued by the European Telecommunications Standards Institute (ETSI). The GSM standard does not include the 3G UMTS CDMA-based technology nor the 4G LTE OFDMA-based technology standards issued by the 3GPP.[11]"
"HSPA+
On November 5, 2009, TELUS launched HSPA+ services the day after Bell launched its such network.[16] This newer technology eliminates many of the limitations found with CDMA technology. The launch of this additional network allowed TELUS to become the third Canadian carrier to offer iPhone products. The HSPA+ network meant that TELUS saved money by avoiding the purchase of expensive CDMA-based devices while obtaining the more popular HSPA devices at a lower cost.
The combined single-channel HSPA+ network is available to 97% of the Canadian population, but there are cases where CDMA service is available where HSPA+ service is not. It provides download speeds of up to 21 Mbit/s, with typical speeds ranging between 4 and 6 Mbit/s. About 70% of the Canadian population are located in TELUS' dual-channel coverage areas, which doubles the maximum throughput to 42 Mbit/s with typical speeds of 7 to 14 Mbit/s.[17]
This network operates on the frequencies of 850/1900*MHz. Although Rogers Wireless and its brand Fido operate HSPA+ networks separate from TELUS and Bell, they transmit using the same frequencies. While TELUS and Bell use the HSPA+ standard as established by the GSM group, neither company operates a basic 2G GSM network."
I have a wifi repeater in my house in addition to the wireless router. Each is named differently. All you need to do is click Forget This Network on the connection you don't want and it will not automatically connect to it in the future.
