antdun
67
97
Utah
How hard is it to remove the hitch?
I have coils and the car is super low as is, it will definitely scrape on my driveway. I'm thinking of getting the 1.25" hitch for a bike rack.
Removing the receiver drop down part is super easy to do, especially if you keep a driver and socket on hand as I do so I don't need to look around for the 15/16th socket. I just grab it out of my frunk and it just always has the right size on it. I can put on the receiver in like 1 minute.
Air suspension is certainly an advantage for the trailer hitch functionality because it is far closer to the ground than a typical truck or SUV with a receiver, but if when you've put the receiver on you're careful then I think it's fine not being able to adjust the suspension. I just make sure to hit dips in the road (like a drainage ditch in the road for instance) at an angle rather than going straight through and it doesn't scrape. When we're on more major roads where we're going faster they're typically more level and there's no need for concern. That's been my experience anyway.
Reactions: Cheburashka
Cheburashka
2,332
2,844
Los Gatos, CA
Thanks for that feedback. At this point, I'm pretty used to scraping with the coils anyway. I don't mind being extra careful around the driveway for when the bike rack is mounted as long as I can remove it easily.
Is there a point in the cover that ecohitch sells? Do you use it when you take the hitch off?
antdun
67
97
Utah
I mentioned the receiver is easy to put on, and you asked if it's easy to take off. Haha sorry for not reading accurately, but really it's just as easy to put on or off, perhaps easier to take off since...gravity makes it fall out once the bolt is out.
I don't use the EcoHitch cover. I don't really see the point to it. Perhaps there's a tiny aerodynamic advantage, but I haven't seen it. Plus if you drive on gravel roads a lot perhaps there's more gravel or dirt getting up there, but that hasn't been an issue for me when I've driven on gravel roads. If it was like $20 or less I'd consider it, but they sell it for far more than I think it's worth.
cbh03
27
21
Fairfax Station, VA
I just received the TorkLift EcoHitch but have not installed it yet due to the need to cut the access hole in the bumper skin. For anyone that has installed this hitch, did you use a 4 in hole saw as recommended? Any recommendations for not messing this up? TIA
antdun
67
97
Utah
One of the commenters on my YouTube video (linked to in the original post of this thread) mentioned that the Torklift EcoHitch instructions and template page have been updated and don't have the holes overlapping like they were when I did it (as shown in my YouTube video instructions). I think that's a good thing as it makes more room for the chains to be hooked onto the hitch properly. I did use a hole saw, I can't remember off the top of my head right now if it was a 3 inch or 4 inch hole saw, but I think that's a great option. I then used a jig saw to cut out the triangular pieces at the top and bottom between the holes. It makes for a pretty clean cut, but it's certainly gave me pause when doing it to be cutting giant holes in a perfectly good bumper...but it's all for better functionality so it's worth it. Measure twice, cut once! Here's where I did it.
antdun
67
97
Utah
@antdun - I was able to install the EcoHitch this weekend and your video was very helpful, particularly seeing the cutting since mine is a 2014. Thank you!
That's awesome, I'm glad to hear my video helped you out, and now you have additional useful functionality on your Model S!
antdun
67
97
Utah
Torklift has modified their design since this article was published 3 years ago. They've added some plastic washers and probably some other tweaks as well. What I need is a small camera I can fish inside the bumper to see if I can tell how things are going in a year or two, because I'm not going to bother to remove my bumper again just to check on things...unless I got a ton of subscribers and they were clamoring for it then I'd do it for a video perhaps.
Reactions: Superendo
Idaho_Steve
20
10
Meridian, ID
Probably too late with this post but I installed this hitch yesterday on my ‘18 S100D and used my Dremel tool. I cut out the provided template and traced the outline. The Dremel made the cut easily and quickly. Mounting the hitch looks daunting but was surprisingly straightforward and took just an afternoon working by myself. (The YouTube videos helped a lot — way more than the provided instructions IMHO.)
Reactions: cbh03 and antdun
antdun
67
97
Utah
That's awesome, I'm glad to hear the video was helpful!
Reactions: EVCarGUy
DayTrippin
299
267
Jax
This has been a very interesting thread as I am considering purchasing a Model S. Has anyone had any warranty issues who have towed something with their S? I am potentially interested in using a hitch for a bike rack and possibly towing a jetski on its trailer.
The combined weight of trailer and ski would be less than 1,000 pounds. I can't see buying a Y or X to tow something so small especially when I would maybe only tow something twice a month and maybe 15 miles each way.
antdun
67
97
Utah
I have had my car into the service center about four or five times since I installed this trailer hitch and they have never said anything. What a technician told me a while back is that installing a trailer hitch would only void the warranty if there was an issue with the car that they traced back to being probably from towing and the things that I've had replaced are completely unrelated like tail light, sunroof, MCU daughter board etc. So there is some risk that if you had a problem with your suspension system or something like that at the back end of the car and they saw you had a trailer hitch they may attribute it to towing but I think that's a pretty minor probability and the functionality that I've gained has been very worth it to me. 1,000 lbs should be no problem of towing weight. The tongue weight shouldn't exceed 300 lbs.
DayTrippin
299
267
Jax
Thanks for the insight. I have seen some manufacturers really try to stretch to make a warranty issue somehow related to a modification. Years ago I worked for Honda and it was amazing sometimes the things I saw that actually were warranted that clearly were caused by a modification if not outright abuse of the vehicle.
Reactions: antdun
