ModelS3 BMS 6s108p vs 96p in 100kwh
You mean 86p in 100kwh yes?
No, that's battery module nomenclature for how the cells are arranged in serial/parallel
The riddle of the day. So 12.5% more cells in parallel. I wonder if the cells are the same? I assume they are in form factor, but is the chemistry improved? And I assume 6s means 6 serial. Vs no serial before? Are the serial cells a replacement for the low voltage battery? Six of them sounds like about 24 volts. What's that for? Hmmm...ModelS3 BMS 6s108p vs 96p in 100kwh
That's what I assumed. Assuming my horrendous math skills are correct, it should be ~120-125kwh (depending on buffer size).
Got it. "s" is strings, not series. So more cells for more range, but what I like even more than that is more cells in parallel. So more current by a factor of 108/96 and more motor power, baring limiting current in software. Unless, of course, the whole thing is heavily rearchitected so there are only, say, 14 modules.Current 100kwh battery is 16 modules. Each module is 6 serial strings of 86 cells in parallel, for a module voltage of ~25v. 16 modules in serial yields the overall pack voltage of 400v.
Exactly, S sales didn't drop off because it is older than 3, they dropped off because of the price point. A new, cheaper option became available, so even though it doesn't offer the same car, it provides more bang per dollar. A refreshed Model S wouldn't create much more demand, especially if it was just a bigger Model 3 for $30K more.
Why would Tesla want to turn Model S into just a bigger Model 3? They already have one in the works, it's called a Model Y.
Ah.. cool! So what does that imply about cell module and pack construction? The voltage hasn’t changed, so there are no more cells in series.
The Y is taller than the Model 3, but the same footprint. So the pack can't be any bigger. If you take a Model 3 chassis then stretch it and widen it to the same dimensions as the S, you get more space for batteries. That would create an up market where if you wanted the ultimate touring Tesla, you had to buy an S. With a bigger battery pack the Performance S would also be much zippier than the performance 3.
There would have to be some interior additions to justify the higher price too. The standard S would still have to be about $10K-$15K more than a long range Model 3.
Most manufacturers are going to one, or a few platforms for all their cars. Cars have been stretched for decades. The chassis the late 70s and 80s Cadillac deVille was built on was the same chassis as the Chevrolet Impala/Caprice with a section added behind the B pillar to give more backseat legroom. The Buick Park Avenue and Oldsmobile 98 were also built on the same stretched chassis.
Now car companies are taking one basic chassis and stretching and/or widening it as necessary. It saves a lot of expense in manufacturing, as well as providing spare parts. The Model 3 is the most advanced platform Tesla has, so it makes sense to use it as the standard for future development until they come up with the next generation platform.
If I was on the design team I would have advocated for making the platform extendable for a next gen S/X.
The energy rating of the pack as well as the amount of power that can be delivered at any moment is dependent on the total number of cells and the capacity and rating of each cell. The number of cells in series determines the voltage, but the current is determined by how many groups are in parallel. Batteries in series can only provide the current of the weakest cell in the string. So if a single cell can safely provide 1A, at 4V, putting 6 in series will get you a string that can provide 1A at 24V. But put 10 of those strings in parallel and you get an array that is still 24V, but can provide 10A.
Putting cells in series adds up the voltage and putting them in parallel adds up the current capability.
There are trade offs. Higher current requires heavier cabling, but higher voltage requires better insulation. The higher the voltage, the easier it arcs. That's why you get a static shock sometimes. Your body builds up a charge and arcs to a metal object, but in that case the voltage is very high, but the current is tiny, so while it may hurt, it doesn't do any damage.
My question is what does the 108 mean? If it implies 108 in parallel then that means fewer modules.
Interesting.
Right. I’m an electrical engineer so I get all that. My question is what does the 108 mean? If it implies 108 in parallel then that means fewer modules. Unless they’ve changed something in the chassis to make more room, which I doubt. Or perhaps it means that we’re now seeing the 2170 pack, where there are fewer modules, arranged differently?
Interesting.
Tesla deliveries fall—especially for high-end Model S and X
The S/X is dead and can’t be refreshed soon enough. Even the massive price decreases don’t seem to be enticing new buyers. Now what? We all sorta saw this coming but less than half the deliveries of the prior quarter is way worse than I was expecting.
86p.I know the original modules (85KWh and 90KWH) were 6s X 74p. I forget how many are in the 100 KWh pack, but I think it's something like 80p.
Only 4 modules and the pack voltage is 350v - but the pack architecture is dramatically different. So I suppose it’s at least feasible that they would move the S/X to a 350v pack with fewer modules but more cells in each one - someone should do the math on that:I know the Model 3 has fewer modules, but I don't know what the voltage is per module.
A DC-DC converter would also allow superchargers to go to even higher voltages than they do now.
86p.
14 6s108p modules is 9,072 cells.
16 6s86p modules is 8,256 cells.
9% increase? Maybe plausible in the existing footprint? Dunno. My impression was that the 100 pack was already basically at max cell capacity.
I just don’t see that as feasible. Even a 95% efficient converter would throw off massive amounts of waste heat when talking about 250+kW supercharging.
The other obvious question is, why would they bother to heavily redesign the pack around 18650s when 2170s are in the offing? It would seem to be a waste of resources.86p.
Maybe Elon was telling the truth about retaining the 18650s? But why????
Contracts and supplier relationships are a tricky thing.
