No one knows what's coming out of Texas, and Fremont is a closed book.Yes, 1 body, not hundreds or even thousands. I do not think they are ready for mass production of 4680 MY. They may be making the first pack that is going into the first body, then all of that needs to be tested in house before making a few more for sending out for legal testing. It is very unlikely they are going from the equipment being delivered 2 months ago and experiencing problems even making 4680 cell components to making packs for mass producing within 2 months. The line was ust pictured as being installed 2 weeks ago so again, they might not even be making successful 4680 cells yet, the equipment is there but the process may not be figured out yet. They are set to use 2170 to start per Elon in August.
Tesla Giga Texas Receives Equipment for 4680 Battery Cell Production
Tesla Giga Texas continues to receive equipment to manufacture 4680 battery cells as the manufacturer aims to begin mass production in 2022. A truck with a container that says "anode line 1" drove into a building on the north side.www.tesmanian.com
Until the backlog for MY is eaten through where they can pause Fremont and Texas while switching over, there is no reason to switch to 4680. Remember all the castings at Fremont they are just starting to work through? They will do the same with 4680. They need to stockpile enough to make 4,000 cars per week. And unless they switch all of one type of car to Fremont and another type to Austin, they will not make multiple models of Model Y that will be different where you are in the country. Do you charge different prices? At some point Tesla will need to pause and have everything be the same at both plants in the US, that is when 4680 will be introduced. There is no sign of that happening soon in Fremont and if Austin is ready to produce MY with 2170, they will conitnue with that until they can do the changeover properly. Remember no Model S for a year when Plaid was being introduced?
Only inferences can be made, there's no hard evidence.
Tesla ain't talking.
Inferences:
The calibration body in white (BiW) delivered to Tesla this week had no floorpan, and people are speculating that all MY will thus be 4680 from now on.
They forget that Elon stated a 'backup plan' using 2170 packs was developed. Both 4680 and 2170 pack-based chassis were shown at the Berlin open house.
Depending on which pack gets used, there's some variance to the BiW - the 4680 is structural, the 2170 pack is not / needs additional floor reinforcement.
In Fremont, they've been making REAR megacasts for a long time, and rolling them inside for chassis assembly since early 2021.
They have also been making FRONT magacasts since summer, and storing them outside on the lot. Lately there's evidence of shuffling, if not reduction, of stacks.
So it seems the use of New Battery Packs is about to commence. 2170/4680 ? UNKNOWN
Further, there's a new all-weather causeway (conduit) finalizing construction between the chassis assembly and new Sprung tent, for moving BiW chassis.
(currently they tow, outside, BiW on rolling frames between buildings) This indirectly indicates a new process to commence.
The new chassis will use both F+R magacasts, and either a structural (4680) or non-structural (2170) battery pack.
Background
Tesla has been capable of making the new chassis battery packs for some time.
Tesla has stated often they anticipate major time + cost savings in building the new chassis (call it v1.5-2170, v2.0-4680)
Time due to few robots, simpler process.
Cost due to keeping the margins on the batteries for themselves instead of giving that to Panasonic. et al. And of course, time is money too.
If they anticipated 4680 would be available soon, they'd wait a reasonable time for it. Just do the process change ONCE.
If 4680 battery packs were going to be delayed, they'd just go ahead with 2170 packs. Then do the process change TWICE (ie, again when 4680 came online).
IMHO
Tesla are engineering nerds first. They want the best possible, soonest.
Events at Texas and Berlin have conspired to delay those factories until now (vs planned September-ish).
4680 may have arrived (finally). It too is later than planned.
SUMMARY
I think Texas will begin with 4680 chassis builds, and Fremont is in the process of doing so as well.
All the delays have contributed to the engineering-preferred solution coming together !!
remember, YMMV
2170 battery packs could still be the interim solution. Which wouldn't be too bad, it would still save 200lbs weight (vs 440lbs using 4680 packs)
