The letters are little stickers. Check this out Want painted calipers? Don't want to spend $600+ on them?
Those are the standard calipers, they just get pushed out via machined aluminum brackets to fit the larger rotors. She has stock silver calipers painted red.BBK is Big Brake Kit? If the rotors are larger, then what did you use for the larger calipers? I see they are red, are they performance calipers? Did you buy them off ebay or something?
Looks good!
Does upgrading the rotors and pads make the P3D Stealth as performant on the track as the P3D with PUP (track mode aside since who knows we might get it someday)?Yep, true. In previous cars when I've upgraded to BBKs they always had both larger calipers and larger/upgraded rotors.. so this is not really a BBK in that traditional sense
I like them though
I would say yes and even more performant if you also replaced the tires and wheels.Does upgrading the rotors and pads make the P3D Stealth as performant on the track as the P3D with PUP (track mode aside since who knows we might get it someday)?
Both are Brembo 4 piston calipers. They both have similar if not equal stopping power. The only difference is in heat management.
According to Sasha at MPP, the caliper differences between the P3D+ and P3D- are very small. Both are Brembo 4 piston calipers. They both have similar if not equal stopping power. The only difference is in heat management. The P3D+ with its larger rotors dissipate heat better than the P3D- stock rotors so they experience less brake fade on continuous use. The MPP rotors are bigger (365mm) than the P3D+ stock rotors.They are also slotted, vented, and lighter. So they stay cooler thwarting brake fade even better than the P3D+ rotors.
But to put that stopping power to the ground, you'll need better tires comparable to the Michelin PS4 that come with the P3D+ or better. And lighter wheels will also help. Getting some light 19" (minimum diameter to clear MPP rotors) will actually be better than the heavy 20" that come with the P3D+.
I will update the website!
MPP Rear Rotor: 13.09lb
OEM Rear Rotor: 16.88lb
Can you take a picture of the clearance between the pad and rotor hat?
Thank you!Not easily 2 front rotor pics
tires need rotating, if it stops raining for a day or 2 I'll takes pics then
View attachment 382561 View attachment 382562
I have not looked into changing brake fluid, I have done flushes in the past but I never feel like I get 100% of the old fluid out. Is there a special machine needed to switch to DOT4. Just curious, I'm not going to do that just yet.
That does not look right to me. Maybe it's just the angle of the picture? Is it stopping ok?
Oh good! I can see why you were concerned though!Confirmed with MPP that it is correct.
Stopped last night after one side to confirm all was good. Will complete the other side here shortly and report back.
Was a there a noticeable difference with the rear rotors? I have the front rotors with MPP pads and brake fluid. I love the set up but was wondering if the rear rotors was actually worth doing if I am not intending to track.Not easily 2 front rotor pics
