Also, if you're giving any thought to selectable options, is there a way to override which camera is showing? For example, I prefer to have the REAR camera showing while driving forward almost 99% of the time. I'd like to switch to forward and rear camera optionally (Maybe via remote fob? I know you didn't like the fob option on your hdmi switcher, but I do use it all the time).
If you use normal camera (90degree viewing angle) for side cameras, since the camera is facing towards to the ground, it can only cover the middle half of the carI agree I don't think any markings are necessary..
Any chance we can get two options I hate fisheye. So we can buy cameras with fisheye or cameras without.
PLEASE...
Re some of the questions:
- Fish eye: This demo is using all fish eye cameras (front/left/right) because these were installed on my car and these are actually the cameras in the 360 system. Also I would prefer to use fisheye for all those views as it covers all angles, the tradeoff is that the distortion, the images had been processed with distortion correction in the demo video. Also this product is mostly used for parking, isn't it?
- OSD overlay: Will take to the software engineer to see if it can be implemented as an option.
for your application, I think you should need the camera like the OEM repeater cameras.I would love to use it as a lane camera when changing lanes. And the front for driving over step drive ways
I like this approach. I actually use the keyfob on your hdmi switch and not the menu button, so I'd like to keep it that way. I'd use the menu button for your quad camera box, and will switch to the hdmi input via my remote fob.the mechanism is that , when you turn on the car, the default view is rearview (stock rearview camera), once you press and hold the menu button for 1sec, it will switch to the 3 camera system on the board (front/left/right), and while it is on the 3 camera system view , the default image is frontview, if left turn indicator is trigger, it will switch to leftview, and right turn indicator will get right view image.
We currently using the "menu" button for the switching between the rear camera and the 3 camera system as testing stage. Will find out an alternative button other than "menu" button for the switching so as to avoid to conflict to the HDMI Interface Box.
ethe mechanism is that , when you turn on the car, the default view is rearview (stock rearview camera), once you press and hold the menu button for 1sec, it will switch to the 3 camera system on the board (front/left/right), and while it is on the 3 camera system view , the default image is frontview, if left turn indicator is trigger, it will switch to leftview, and right turn indicator will get right view image.
Read my post again. Key fob initiates hdmi box...which you absolutely don't need for driving.Fumble with getting key fob out of your pocket IS NOT THE WAY TO GO....definitely bad idea
@Wratran, The keyFob that kdday is reffering to is not the OEM carshaped Keyfob we all use to access the car.Again...fumbling with the key fob is stupid..getting it out of your pocket while driving ..or before driving is not necessary.
Switching should be done on steering wheels buttons or screen.
That the whole idea behind a “auto entry”... not to mess with key fob in anyway.
My wife always have her key the purse
