Sunshine Speed
When replacing my gas furnace and outdoor electric AC, I originally wanted ductless mini splits, because of the cleanliness (no ducts, no dust/crap collecting in ducts). In the end, I decided to replace my existing 1965 ducting with brand new flex ducting and get a single whole-house 4-ton heat pump.
Benefits of single outdoor heat pump feeding blower in attic with 2 zones and 2 thermostats (upstairs/downstairs):
- For single heat pump, outside of house only has one set of refrigerant/electric line running from heat pump to attic (whereas ductless mini split refrigerant and wiring has several runs from outdoor units on multiple walls to indoor units, and makes outside walls of house look ugly)
- Only one outdoor heat pump to maintain (whereas ductless mini splits require occasional maintenance at every indoor unit)
- Simple vent/register in each room looks better than the ductless mini splits in various rooms.
- Cheaper to install single 4-ton heat pump (vs mini splits) if attic already had previous ducting and every room already has registers/vents.
- Every room in the upstairs or downstairs is always heated or cooled automatically from registers, no need to manage individual rooms and ensure doors to those rooms are closed.
- Even quieter operation compared to mini splits because of continuously variable speed heat pump and blower can run at quiet low speeds in attic.
Benefits of ductless mini splits:
- No need to create ductwork for homes that don't already have it.
- Ducts are disgusting and collect dust and crap over the years, so it's best to not have any.
- If any single unit breaks, other units in various rooms can still cool or heat the home.
- If you want to save money, you can turn off various individual rooms (whereas with my system I can only turn off whole upstairs or whole downstairs).
Hope this helps.
Hope this helps.
