Another member went further with less camber
you rang...........
the < 1 club present.
But what was the rear toe measurement??? That's the critical one.My SC agreed to cover the cost of tires IF they were found to be out of alignment...
"Within specs" is -1.75 +/- 0.35, i.e. -1.4 to -2.1
Mine was -2.02
anything over about 0.210" longer than stock will have you run out of toe adjustment.....
0.210" longer is good for reducing negative camber by about a degree depending on where your upright neutral position is (ride height).
I mentioned 0.210 to BBC and their feeling was make it adjustable which would allow for imperfections and let everyone adjust to their maximum benefit before losing toe. Also in the event adjustable toe links are made additional adjustment can be done without replacing the upper links.
Could you give some more info on this? Will these aftermarket links be commercially available? Any time frame when?
Installed the links today will update with alignment results next week. The links fit perfectly and took no time to install.
Awesome job.
Am I the only reading this thinking how absolutely fcuking absurd this is? I can't even imagine what would happen if BMW released a car that burned through tires like this and owners going to the trouble to machine their own parts. Tesla should be doing this. I can already tell that my rears will wear unevenly again but don't want to bother my SC.
The suspension engineers for tesla should be replaced.
I have hard time buying this explanation but do not have a better one.I've not confirmed this with Tesla engineering but the only reason I can think of for not using the same alignment specifications on the lower air suspended cars was to keep from having yet another set of suspension to keep track of. My GUESS is they have this problem for cost reasons only but do not think for a moment that Tesla is special on this one.
Suprkar: Please suggest to BBC that they also include "no slop" bolts with the customs arms for those of us that have the updated bolts.
