Suprkar: Please suggest to BBC that they also include "no slop" bolts with the customs arms for those of us that have the updated bolts.
no slops:
Bolt HF M12x1.75x70 [10.9]-U-G720 p/n 2007078
BBC is also making a bushing which will fit the link so when these are done you will not have to press out your bushings, just purchase the links and install.
no slops:
How close are these bushings to the OEM ones from Tesla? Will they be like the stiffer ones in all of the P+ links?
IIRC, when @lolachampcar was investigating doing modified links the manufacturer of the Tesla OEM bushings was unwilling to sell them to him.
Agreed. I took an hour to read through this thread and need another go just to get conversational on tire camber.
I have a p85 with 21" tires and I am on my fourth set at 25k miles. The ones I just replaced had the same inside tread wear. Do I need to have an alignment shop reduce the camber as much as possible until these new links become available?
Gws,
I'm in WPB and can put you together with my alignment guy......... and do not hesitate to drop me a note if I can help.
Bill
It's a simple result of good basic suspension design. All good suspension designs have a bit of dynamic camber so that as as the body rolls into a turn and compresses the outside wheels, you increase the amount of negative camber to keep the tires flatter on the road which increases grip.What was Tesla thinking here? Is this the result of track testing, where the track is flat or has slightly banked turns and so is not real world? Could it be something they simply overlooked, or didn't have time to get to? What happens with other ride height adjustable cars (not trucks)?
Yeah, it's a compromise when you have an adjustable height suspension, but in a straight line tire wear should be minimal anyway as long as your toe settings are correct.
While a good point that incorrect toe is the alignment spec that causes the worst tire wear, perhaps I wasn't being clear in that I would have thought that Tesla would have thought outside the box and designed Model S such that the adjustable ride height would not affect things like camber. Maybe no-body else does this, but that doesn't mean it couldn't/shouldn't be done.
BTW, does anyone know how much camber changes between each of the different height settings? An owner with an accurate digital level should be able to find out in under 15 minutes.
I would have liked inboard brakes which allow even greater suspension design flexibility and vastly reduced unsprung weight, as well as allow a much greater range of tire and wheel sizes.
My '66 Jag EType had those in the rear. Made replacing pads a bit of a pain and the rotors weren't ventilated so without exposure to air flow from the wheels, they overheated really easily.
I use brake dust as a measure of pad wear and MS is a champ when it comes to keeping its rims clean (in comparison to an ICE).
