I'm not sure there are enough data points to come to a consensus.I'm still curious what the concensus is with regards to my questions in post #391
Guys, Thanks for providing so much information!
I am planning to lower the car by using the lowing links for the air suspension, and since there isn't any adjustable camber (and toe?) arms available on the market, is there any other option for me to correct the camber?
If you are trying minimize your negative camber while utilizing existing unmodified TL's, have you considered maxing (or very close) out the toe eccentric and then use your new adjustable UL's to set your toe? (I do realize that this is an unconventional reverse approach but would maximize your effort with OEM TL's)
I want to set rear camber to ~1 dgr. I think the factory toe links have enough range for that, so I'd want just the upper links.
Will they offer either steel or aluminum? The links are so short that doing them in steel is fine as far as I'm concerned. Weight difference ought to be insignificant Any chance of some pictures of the prototypes?
Thanks, hadn't seen the picture. The steel version looks good. 1 lb is nothing I'd worry about. Only half of it is unsprung. The one thing I would worry about is the jam nuts loosening. But that's why they have a guinea pig for them.![]()
