Who has worn out a set of tires the fastest? There has to be some members that have replaced tires already!
The conti is a 340 treadwear and the Pilots are 220 but both "AA A" for traction and wet. So I would expect shorter life w/ the Pilots (and they are twice the price). Our MS is a daily driver so I'll be sticking w/ the Contis.I've read posts from two differnt owners that have done in rears, one at 5500 miles with the inside shoulder gone.
The added grip of the Pilots over the Contis is probably what is driving the increased range.
Is this camber/toe issue specific to the 21s? Do you think the 19s on a P85 will have the same inside wear issue?
(2) the contact patch is smaller making the disparity between outside and inside loading less.
Tesla is using darn near zero toe; probably to reduce rolling resistance.
Old wife's tale or not, I follow the conventional wisdom that you do move radials so that they rotate in the opposite direction. I've had belts slip/break doing this in the past so I no longer do it.
That being said, I have moved tires across the back of cars such that the "outside" label is on the inside without any issues at all. This has effectively allowed me to get most all the use from a set of rear tires. This goes against the manufacturer's recommendation but I have never had a handling or wear issue doing it. That's my 2 cents.
OOPs, just saw the Norway.... TUV will not approve of doing the above.
The stock Goodyear 19" tires are marked for inside and outside; I take it you believe there's no harm in swapping left and right rears (requiring dismounting and remounting) so that direction of rotation remains the same, but inside and outside are reversed. If that's true, why do manufacturers bother marking inside and outside?
