So AWD is 147kW + 188kW for 335kW and PAWD is 147kW + 211kW for 358kW. Performance is not even 10% more power? Seems a bit strange, no?
The biggest difference will the be maxtorque setting, not any power. That is what people notice in the first two seconds of acceleration. No way can the difference in 0-60 be attributed to just the difference in maxpower because that car w 446Nm torque and 358kW power only does a non rollout 4.26 0-60. More importantly the car would feel like the RWD for the first two seconds, so no way that happens.
My bet is the rear motor can currently handle more torque and that they increase the rear torque max and total torque max settings in the P from 450Nm to 575Nm. If that is true and Tesla optimizes the front motor for high speed power. it looks like this in yellow...
...and if true my bet on the AWD is no increase in torque so consequently most will not notice the 0-60 difference because it will simply be that the car continues to accelerate for slightly longer at max torque until the new higher power limit of 335kW. Highlighted in orange. I built this on the
@DarthPierce modelling. After DarthPierce checks my work I'll put it in the performance Metrics.
My bet is the induction motor is optimized for high speed power not low end torque. This would be amazing in quartermile and halfmile times shown above. If I am wrong then those numbers will be off because the power will drop from the field weakening (Back EMF) at high speeds. Likely to roadster will have that low speed rear and high speed front motor optimization.
There is a substantial difference from the Model S in that the rear motor in the non-P Model S is physically smaller than Model S P. Here it is the same size motor is both and the D is just having less current run through it. It'll be interesting to see both the P and D run on a dyno to get an idea of the differences in the shape of the power curves that Tesla has programmed for them.
There aren't really programmed power curves. There are maxtorque and maxpower settings that, combined with the BackEMF of the motor combination chosen create that performance shape. But in the Model 3 RWD the maxpower may not even get reached with the current motor characteristics of field weakening or Back EMF. You don't need to get on a dyno to measure these. You could do it from your iphone or android device with a little math to calculate the torque before the API stopped working. Here's hoping that API stop is just a change in the API that hasn't been caught yet by the third party API developers.
...it's a software limitation...appears to be the same battery pack in all LR cars... (which is 1200 amp max output...
This. Exactly.
...Tesla are sandbagging the performance in software...I'm hoping that Tesla uncorks it a bit more once they work through the backlog of deliveries...
Since this is a source of differentiation between AWD and P as well as between the 3D, P3D, and all S models, Tesla would have to uncork a bunch of cars. Could happen. There might be some magic in the new S drive units for increasing torque. Probably not in the S batteries.
...I expect we'll need to wait until well into the fall to have a solid answer on it, for some brave soul to pull one apart...
All we'd need is one highspeed runlog over the API (assuming it gets fixed) or early AWD and P adopters to hookup the CANbus adapter in the 2. But a dyno works too.
