The reason for your confusion is the Tesla rep is giving info based on what’s being built currently, which is cars with 48A chargers.
Apparently they still do as I have one that I assume was built in the last couple of months or so. Can one tell when it actually rolled off the line from the VIN.He doesn’t know that Tesla built cars with 72A chargers until very recently.
Why doesn't that surprise me?Understand that the average Tesla rep knows less than many owners
I wouldn't advise people to install a 100 A circuit as that requires pulling #3 through 1" EMT which has got to be a real joy (I suppose you could do the long part of the pull through a larger conduit and transition down to 1" or use a reducing bushing, if such things exist for EMT, for the last bit) and it doesn't buy you anything as the charger in my car is limited to 72 A for which a 90 Amp breaker and #4 are adequate.If your car has a 72A charger and want to take full advantage of it, install a 90A or 100A circuit.
Unlike traditional auto companies, “built in the last couple of months or so” is ancient history for Tesla. The cars are continually changed (Tesla would say continuously improved, but I don’t consider going from 72A charger to 48A charger in the 100 kWh cars an improvement).Apparently they still do as I have one that I assume was built in the last couple of months or so.
It's a very recent change. Like mid-Nov. My parents just picked up an inventory S 100D that was built in Nov. It has the 72A charger. Any S or X coming off the line now does not. They only have a 48A. Again, the change only happened a few weeks ago.My car was built in late 2018. It has a 72 Amp charger.
If you have a 100 that was built pre-mid-Nov, it has a 72A. After mid-Nov, 48A. You cannot tell manufacture date (or order) by the VIN number; Tesla assigns VIN's in somewhat random order (not sequentially).Apparently they still do as I have one that I assume was built in the last couple of months or so. Can one tell when it actually rolled off the line from the VIN.
If it’s like my Model 3, the month and year of manufacture are on the upper left corner of the white tire sticker. Mine says “03/18” (without indicating that means month and year of manufacture). Speaking of which, your car isn’t really a “2018 model” as Tesla doesn’t do model years. It may have to be called that for registration and insurance purposes but if Tesla had its way it wouldn’t be called that, as they continuously change the cars and calling it a 2018 model implies it’s similar to others built in 2018 when that may not be the case.I'm feeling pretty stupid right now but I can't find anything on the driver's door jamb except the tire inflation sticker. Where should this sticker be relative to that? I've checked driver and passenger side front doors with no luck.
I'm happy. I've got a 72 amp machine but I'd like to get to the bottom of this for the sake of others. The car is a 2018 model and as I gather the X's are selling pretty well (through Q2 they were selling about as many X's as S's) I'm assuming that this one wasn't made last January but I suppose it could have been.
Manufacture month and year is also on your window sticker.The only numbers on the tire sticker are 137972. If that represents a date it must be from the Aztec calendar.
That won't help me much. My 'window' sticker was not attached to the car but rather handed to me by the delivery guy. In the excitement I just set it down somewhere and in my house you don't do that. If it's there, whatever it is (including letters from the IRS) it's in the garbage within 10 minutes.
They can't use up all of the 72A chargers on new production; they need spares to replace failed modules in customer cars.OTOH it also suggests that they had a bunch of high amperage chargers left over from a previous production run and are going to keep installing them until they run out of them.
This keeps getting more interesting though. I'm now hooked up to a 50 A breaker and I can ask for 40 amps which I get so with a line voltage of 238 the power supply is pulling 9.52 kW, right? Well no. It is actually pulling 9.52 kVA but the real power is only 7 kW. IOW the actual charging current is only 30 Amps (power factor 0.74)! The thing is pulling 6.4 kVAR too. Where is that going? I guess there has got to be a boost mode DC/DC converter right behind a rectifier in there and that, of course, would involve a fat inductor but I'm surprised the power factor is that low.
You gave me a bad turn here fot a minute because when I saw the question I couldn't remember! That happens when you get to be my age. But then it came back to me. I got them by comparing the power drawn by the panel to which WC was connected to the VA drawn by that panel. [/QUOTE]Where are you measuring these numbers?
Yes, in 50 years of electrical engineering I have gained a passing acquaintance with some of these termsDo you understand the difference between them?
Not quite but sort of.VA (volt-amps) is just the product of the voltage and amperage. It is called "apparent" power.
W (watts) is the real power and is the product of volts and amps times a factor that adjusts for the difference in phase of the two (assuming they are both still sine waves).
You have never heard of Vars before but you are ready to tell us what they are?I've never heard of VAR before, but it is the "reactive" power.
Clearly these are switching supplies. They can be pf corrected by intelligent gating algorithms. I want to look at the current waveform but I think I must have left my oscilloscope at out summer house.In power supplies the power factor can vary a lot from unity if not corrected for because the current can be more spiky and not as much like a sine wave.
I was surprised that the power factor I calculated was as low as it was but pf's of 0.8 are certainly not unusual. But as it turns out the true pf for these supplies is 0.9 - 1.0, higher when it counts at fuller load.I am surprised this is happening with the Tesla chargers. I'm not a power supply designer so I don't know all the regulations, but I thought larger power devices did have requirements to meet in this regard.
You gave me a bad turn here fot a minute because when I saw the question I couldn't remember! That happens when you get to be my age. But then it came back to me. I got them by comparing the power drawn by the panel to which WC was connected to the VA drawn by that panel. Yes, in 50 years of electrical engineering I have gained a passing acquaintance with some of these terms
Vars are the imaginary part of the integral of the product of voltage and the complex conjugate of the current divided by the time over which the integral was computed.
Voltage and current are both complex, usually periodic functions of time here. The real part of this normalized integral is the actual power delivered to the load i.e. watts or joules per second delivered to the load. Vars can be though to as joules per second stored by a component and subsequently restored to the system - sort of the power that would be delivered by an imaginary current. There several reasons to track vars the pertinent one here being that the reactive current (vars divided by voltage) is a real current that warms conductors.
Power factor is the ratio of the magnitude of the imaginary part of the integral to its magnitude, If the voltage and current waveforms are both sinusoids of a single frequency then it is the cosine of the phase angle between them and represents the fraction of the product of rms voltage and rms current that is delivered to the load as real power.
You seem to have some familiarity with some of these concepts but this isn't EE school. What is of interest here is the properties of the OBC. I took some measurements from which I conclude that the OBC was an inductive load. The problem is that the measurements I took were invalid as there was a problem with the CT (current transformer) measuring one of the phases to the panel. I corrected this and then took the further step of installing a CT directly on the branch feeding the WC so I could get a direct pf measurement. When the load is small (towards end of charge0 the pf goes down to 0.92 - 0.95 but when the load is 40 amps it is essentially 1.
