The HWPC's best benefit is when you have more than one Tesla. We have 4 Teslas currently and at any given time, we have 3 of them plugged in. The HPWCs allow us to have one main breaker which is load balanced/shared between 3 wall connectors (up to 4 are supported) and it automatically splits the load between cars that are actively charging. We currently only have 64 amps (on an 80 amp breaker) split between the 3 HPWCs. That allows one car to charge at 48 amps, 2 cars to charge at 32 amps each or 3 cars to charge at 21 amps each. We have the wiring to up it to 80 amps (on a 100 amp breaker) which would allow us to have 1 car at 48 amps, 2 cars at 40 amps each or 3 cars at 26 amps each but were told we need a firmware update on our Powerwalls before we can bump things up. If our cars had more than a 48 amp chargers, then we'd be able to charge an individual car at 64 to 72 amps.Personally, I see the corded HPWC as a bit of a waste, unless you already have the NEMA 14-50 installed. Then it's essentially just a nicer looking, more permanently attached gen 1 UMC. If you need to involve an electrician, then just hard wiring it at 60A is the better path.
Of course we don't usually schedule all cars to charge at the same time...but if they need to, we don't have to consider the load since the HPWCs handle it automatically. Previously, we had 2 14-50 outlets and were able to have two cars plugged in at once but we didn't have the ability to have 3 cars charging at 240 volts simultaneously.
