Aziatiklover
ack that sucks. i wonder how easy it is to make it the manual version? how do those work anyway, do you just push it in and it will pop open? just thought about it in case i ever broke mine, plus the electric door isnt that great anywayView attachment 1055083Broke my charge port door. So I got a brand new one from Tesla for $85.
The description mentions a decoder for the early models. So I'm guessing they've deciphered the various LIN signals and are translating those.Looks like Evoffer is now selling oem matrix for pre-refresh. So did they modify the light or just create a harness ?
Model S Matrix Headlight Upgrade (For 2012-2021 Model)
Tesla has updated the headlight design for the 2022 Model S, featuring Matrix headlights with two crystal lens, significantly enhancing its appearance and brightness! After disassembling, it was discovered that the new version of the headlights has also resolved the "burnt eyebrow" issue, so...evoffer.com
View attachment 1055089Next is gonna be a front lip and MATRIX headlights project.
I tried to pull the trigger but ended up a bit confused about the placement of some of the resistorsJust finished getting them to finally work on my 21 plaid! First of all I cannot thank Alpharex enough! These guys told me exactly what to buy. They tried to get me to wait for the harness, but I insisted so they insisted on helping me. One of the resistors showed up late, but they even checked in on me to see how progress was going. Customer service is amazing. no thanks to TSportline.. these guys got right on it. I’ll post a YouTube video with detailed directions and try and have it up tomorrow. I’ll post some videos of them at night once it gets dark. Obviously I got the smoke and they look great on Black!
View attachment 1053971View attachment 1053972View attachment 1053973
No just the headlights. Unless I have someone like you that want to swap the front bumpers lol.Do you mean the entire front facia ? I have a 21 Refresh and like yours better than mine !
For me 2017 MS is the B version LHD. So, it looks like straight PNP. Do you know if it is the same scenario if I get the Matrix headlights from Ebay for around ~$600 the pair and get the harness? I'm hoping for a straight PNP.Looks like Evoffer is now selling oem matrix for pre-refresh. So did they modify the light or just create a harness ?
I believe evoffer modified the adapters. I don’t believe they sell them separatelyFor me 2017 MS is the B version LHD. So, it looks like straight PNP. Do you know if it is the same scenario if I get the Matrix headlights from Ebay for around ~$600 the pair and get the harness? I'm hoping for a straight PNP.
This is for 2021 variant C which is not PNP.
* For Variant C cars, we offer like new headlight sets + adapter wire + car config change.
You need to prepare a laptop running Windows system and a Ethernet to Ethernet Cable for car config.
To my understanding:
- the 2 Ohm .25W resistors will be a total of 6: 2 on each outer light (1 on the green wire and 1 on the yellow wire) and 1 on each inner light (green wire)
- the 50 Ohm 10W resistors (orange) will be a total of 2: needs to be installed within the wiring of the car before reaching the other 2 Ohm resistor, using T-Taps? This is where i am a bit lost. Does it tap from within the wire of the car, a yellow wire? And there was a mention "not to need to cut the wire"
- The 3rd brake light resistor -- I am a bit lost there
- The 0.5 Ohm 100W resistors (green) will be a total of 2: 1 on each of the outer lights, through the yellow wire (that connects with the large plug)
am I correct?
update: I understand now the portion of the 3rd brake light based off this photo from an earlier post
Doing some more digging around throughout the thread to gather all the necessary info in one place, will update!
AppreciatedSo the 50ohm 10w resistor will install before the 2ohm resistor. One wire from the 50ohm 10w resistor will tap into the yellow and the other wire of the 50ohm 10w resistor will tap into the black/ground wire. Everything else u have it wired right
Looks great! Any pictures with the lights off?Couple more for you
Here is my initial soldering process with the 0.2ohm resistors
Selected the yellow and green wires of the outer light
