sure ET will vary if the car spins even a tiny bit, look at the TRC slips, when he didn't spin, they were within ~.03 of each other and keep in mind he was switching lanes. The Tesla is incredibly consistent. He also isn't charging between tests to keep the SOC equal as I was. The traps are also a good indicator as they are not effected that much by the initial launch.
If your 'noise' tolerance is .05, then there you have it, 140 pounds of weight or the "guessed" weight of the pano roof is insignificant for a 1/4 mile pass. BTW, as I loaded up 140 pounds into the car, I have a hard time accepting the two panes of glass and some motor hardware add that much weight.
I have plenty of other runs, but I won't use them since they might have been on a different road, different SOC, different firmware, different tire read depth, mileage, etc. Back to back testing is the only way as this was done.
Yeah, I agree it looks doubtful, but I'd like to see how weight affects tesla's ets. You really can't do it with just two points. We need to now how much noise is on the data. In addition to the data from the other runs here, do you have any more runs of just you in the car? The more the better so we can get a handle on how much the times change from run to run. You may be more consistent, but trc's runs varied by a 0.1 secs with no change in weight.
Do you know the weight of your car?
And just out of curiosity, what pressure did have in your tires? Did you lower the pressure in hopes of better traction?
Thanks
