Perhaps the new Roadster would need to be developed away from the mothership. It takes up resources needed to make normal familycars happen without delay or distraction.
If a separate team were to be formed with access to Tesla's research and tech, what could they build? The low budget but high price Rimac Concept One offers a first insight in the possibilities.
I'd love to know more about proven battery technologies. For peak power, small batteries can do a good job but offering low range. Koenigsegg has a 75kg 4.5kWh 800V 525kW battery that get then 20-30 miles of e-range. Not light enough to use 20 of them, obviously.
But one of these supplementing an internal Tesla 2170 60kWh for lap attack unit and a removable (pit stop) 60kWh unit, There would never be need for more power, and in total decent range with a battery weight that can be built around.
Rimac's front drive train might be worth taking a licence on. Rear DT might suffice with a standard large Tesla unit plus proprietary cooling. Now all that with a chassis that's not a porker.
I like the idea of a range extender pack (this second 60kWh) that is bolted centrally under the car.
In lap attack mode, it would have peak power of 525kW from the small battery and 300+kW from the internal 60kWh pack. Enough total to be quick. The small battery is good at not overheating too much, the 60 makes up the laps and feeds the small battery as hard as it will be charged. My math may well be too optimistic, internal 2170 pack may need to be larger. But in a race situation, it may be interesting to have to start on the extender, and only be allow to drop it off in the pits, then a larger extender is good to deplete first and then drop during a tire stop. Could make for interesting racing.
Lap attack might even work with just 2 or 3 of the small modular batteries. More need for power, more desire to save weight, less to have range.
On a light car with lots of torque, I'd spec a longer gear ratio. Race cars seldomly dip below 50kph, and need the top end. At low speeds, traction is the limiting factor moreso than power.
