I have very grave reservations about the whole concept of V2G, given that the cycling requirement for grid support is absolutely massive when compared to the normal cycling pattern seen by an EV battery. Cycle life isn't a big driver for EV battery design, as EVs never really cycle their battery packs very much at all. As a consequence, cells intended for EV use are designed to accept high charge and discharge rates, and have a long calendar life, but they never really need much in the way of cycle life - the equivalent of 1,000 full cycles is more than enough for the typical lifetime of a car.
For example, take an EV with a range of 250 miles, that's driven 10,000 miles a year. It will undergo the equivalent of around 40 full battery cycles a year. In comparison, a battery pack used to provide grid support is going to cycle at least once a day in winter, and probably twice a day for most of the summer. It will easily undergo ten times more cycles per year than the battery pack in a car.
There are battery chemistries that are better suited to being cycled a lot. LiFePo4 is one, and the chemistry used in the well-proven Pylontech packs, that have around ten times the cycle life capability of LiCoO2 or NMC cells. They have nowhere near the energy density, but this doesn't really matter for a stationary pack assisting the grid - size and weight aren't major design considerations for such an application.
The reason that so much work is being done on other bulky, but very high cycle life battery chemistries, like redox flow cells, is related to this requirement for a very high cycle life for battery packs intended for grid support. Ideally, these batteries need to last for decades, with little or no loss in capacity.
