TN Mtn Man
And I thought Spokane's potholes were a problem!If you thought Toronto streetcars were the problem here is another FSD edge case:
Will Bond be allowed the use of a Roadster though if Tesla does not pay for product placement?Next Bond movie: Bond flees villain in his Tesla roadster, encounters land mine in middle of road, engages cold air thruster, hops over mine, villain hits it and explodes. This stuff writes itself.
Finally I understand why Tesla is talking about adding cold air thrusters and flying to the Roadster.
Or potentially air could catch underneath the mines and flip them over which would be equally bad.HP air from cold gas rocket nozzles flying in ground effect would likely cause those mines to detonate anyway. Touchy things, those fuzes. And some fuzes are MAGNETICALLY activated (even with carbon fiber / non-ferrous chassis components, there's still the magnetics in the motors which will be detectible by the mines).
Hopefully not something I'll ever need to worry over. Cybertruck won't have air thrusters anyhow.
According to Elon it was Blade Runner, with obvious similarities.I sure this V-bottomed hull, flat-panel type of ACP is what inspired Cybertruck design for Elon in the first place.
It works in Nordic countries as do air source heat pumps. I have seen videos on YouTube by a guy who reckons they won’t work in UK very well due to the crap sealing on housing stock obviously old houses primarily but even the newbuild stuff is nowhere near as sealed as Scandinavian houses. I’d be happy to see some proper evidence from someone with a better understanding of them though.I just listened to Dandelionenergy.com interview with ARC. Heat pumps going about 8 ft. underground can heat homes in cold winters and cool homes in summer. Just using energy from heat underneath the earth's surface. This is already happening in the NE US. I would think Germany would love this as alternative energy sources from gas. Combined with solar and batteries no oil/gas needed.
Ground source heat pumps have been available for years using either vertical wells 100ft or more deep or horizontal trenches hundreds of feet long but only 6-10 feet deep. Dandelion has been focusing on reducing the costs of drilling vertical wells by building smaller dedicated drilling rigs instead of the typical water well drillers that have been used to date. If they were talking about 8 ft. underground that must have been referring to horizontal trenches, which can only be done if you have enough acreage.I just listened to Dandelionenergy.com interview with ARC. Heat pumps going about 8 ft. underground can heat homes in cold winters and cool homes in summer. Just using energy from heat underneath the earth's surface.
I've been told the water table in the bay area is only 6 ft below the surface. You'd think with water running down there, it wouldn't take much to tap into that cold/heat reservoir.Ground source heat pumps have been available for years using either vertical wells 100ft or more deep or horizontal trenches hundreds of feet long but only 6-10 feet deep. Dandelion has been focusing on reducing the costs of drilling vertical wells by building smaller dedicated drilling rigs instead of the typical water well drillers that have been used to date. If they were talking about 8 ft. underground that must have been referring to horizontal trenches, which can only be done if you have enough acreage.
They've been around in USA almost 40 years.I just listened to Dandelionenergy.com interview with ARC. Heat pumps going about 8 ft. underground can heat homes in cold winters and cool homes in summer. Just using energy from heat underneath the earth's surface. This is already happening in the NE US. I would think Germany would love this as alternative energy sources from gas. Combined with solar and batteries no oil/gas needed.
going a bit off topic.I just listened to Dandelionenergy.com interview with ARC. Heat pumps going about 8 ft. underground can heat homes in cold winters and cool homes in summer. Just using energy from heat underneath the earth's surface. This is already happening in the NE US. I would think Germany would love this as alternative energy sources from gas. Combined with solar and batteries no oil/gas needed.
The deeper the better, but many air source heat pumps manage to extract heat from -15F surface air. Ponds are also great heat sources for geothermal heat pump systems.going a bit off topic.
I really doubt your 8 ft figure.. we have geothermal heat pumps at the attached houses where I live, and the heat wells go 200 meters underground. Ok climate is colder than Germany. System has a cop of 4-5, and provides only heat (no cooling).
I have just installed a 14kW air source heat pump (ASHP) on a large (240m2/300m2 = c. 2,400 / 3,000 sq ft) and old (1840) house in the UK. It works just fine and is more economical to operate than the oil-fired boiler it replaced that was of approx 45kW. This ASHP is operated entirely off renewable-origin electricity.It works in Nordic countries as do air source heat pumps. I have seen videos on YouTube by a guy who reckons they won’t work in UK very well due to the crap sealing on housing stock obviously old houses primarily but even the newbuild stuff is nowhere near as sealed as Scandinavian houses. I’d be happy to see some proper evidence from someone with a better understanding of them though.
Yes, but the COP suffers. You are looking at cop of 1-2 in the cold, instead of 4-5 that you can get with geothermal. Cop means how much heat you get from used electricity, ideal conditions and cop 5: 1kwh electricity generates 5kwh of heat.The deeper the better, but many air source heat pumps manage to extract heat from -15F surface air. Ponds are also great heat sources for geothermal heat pump systems.
Why can only 5%-10% have ground source? 70 mm thick insulation only? That’s thinner than a stud wall.I have just installed a 14kW air source heat pump (ASHP) on a large (240m2/300m2 = c. 2,400 / 3,000 sq ft) and old (1840) house in the UK. It works just fine and is more economical to operate than the oil-fired boiler it replaced that was of approx 45kW. This ASHP is operated entirely off renewable-origin electricity.
One key is to insulate the building correctly. However understanding heat pumps and sizing them correctly is the other key. Of the six heat pump installers I approached only two came forwards with sensible proposals (i.e. which matched my own engineering calculations*) and only one gave a sensible price. Most of the rest thought the building could not be fitted with an ASHP, or could not do the sums correctly, and plain overcharged, or all of these points.
EDIT : To add that ~90% of typical UK properties can accept an ASHP, whereas only ~5-10% of UK properties can accept a ground source heat pump (GSHP) irrespective of whether it is a borehole style (n boreholes each 100-200 feet deep) or 'slinky' style (n length of trench typically 4-8 ft deep). The UK % I have given would be equally applicable more widely in Europe for similar reasons. Bottom line, we need to focus our efforts on ASHP rather than GSHP.
There is an appalling level of knowledge in the UK heating-engineer community (aka "plumbers") and builders/architects on the use of ASHP and on how to insulate older properties (without creating more problems than one solves). Unfortunately to fix this requires them to throw out bad knowledge ("draughts are good"), learn new knowledge, and adopt very different business models.
It is somewhat different in other countries in Europe, mostly between 10 and 20 years ahead of the UK in these respect. For example I am currently in a property in Greece where the newbuild wall insulation is 70mm, which is thicker than most people would consider installing in the UK. The Greeks are correct, and the UK is wrong. For insight for the UK property I have described the retrofit loft insulation package that I installed now averages 300mm depth, and the wall insulation retrofit package varies between 50-100mm depending on where. The whole world needs to get good at this as part of the energy transformation, and the UK especially needs to pull its socks up and tackle its woeful performance in this area. Keeping this on topic, a side effect of the Russian invasion of Ukraine will be to accelerate this transition in all respects, worldwide.
(* I have the advantage that I was one of the technical oversight team that first approved the development of the standard UK calculation template about 10-years ago. Needless to say my bu11sh1t detector was triggered on many occasions discussing this project with four of the six candidate installers. I should add that the six I approached were the upper quartile of installers in this area of the UK, i.e. all the others are worse. There is a lot of improvement required.)
For GSHP to be suitable for a property the following conditions need to be met:Why can only 5%-10% have ground source? 70 mm thick insulation only? That’s thinner than a stud wall.
