StealthP3D
You meant power; however, your statement was not necessarily wrong.
If final load voltage stays the same (step down DC-DC in module), a wire one fourth the crossection (four times the resistence) at four times the voltage can provide two times the current (or power) to the load with the same self heating (loss).
W_loss=(4R)*(1/2*I)^2=R*I^2
W_new=(4V)*(1/2I)=2*W_old
I see what you're saying but do you think a higher system voltage is a viable option if the accessories are still running on 12 volts? I was under the impression that a higher system voltage would pretty much imply the loads had been converted to run on the higher voltage natively.
I'm not sure why your response was moved out of main. Personally, I think the how, why and when of Tesla switching to a new system voltage would be of huge importance to the way Tesla is viewed by the auto industry and by investors and is too important to ignore. I'm getting pretty fed up with the heavy hand of the mods (well, mostly one mod to be honest) as well as the direct attacks to my character.
