So you have the regen-adjustment feature?I’m out for a drive with my Y, so I thought I’d try and see how the regen works in both low and standard.
The regen is just lower in low. Doesn’t seem to matter if I’m on the brake pedal or not. It’s just lower.
You’ll get used to one pedal driving.
I am sure I get used to it, no doubt.I won’t buy another EV that doesn’t offer one pedal driving. I control deceleration with the accelerator pedal. If I need to slow down quickly, I take my foot off. If I can slow gradually, I gradually reduce pressure on the accelerator pedal until I achieve the desired slowing rate. The goal is always to have the car stop at the stop line, or just behind the car in front. The brake pedal is for emergency stops, or when I’ve miscalculated the stopping distance.
I have a 2020. I’ve always had it.So you have the regen-adjustment feature?
I would think the most efficient would be coasting and regen under the brake pedal.I am sure I get used to it, no doubt.
But I also like the fact that the brake pedal actually activates regen braking in my R4P.
I'll be able to tell which I like better after a few months with the MY.
I have not yet driven an EV with regen on the brake pedal, but I am curious about it. Probably nice on level ground but not as good for downhill speed regulation. I did really like the adjustable regen on the paddle 'shifters' on the Ioniq 5 through when I drove my friends.I would think the most efficient would be coasting and regen under the brake pedal.
It feels no different than regular brakes, Toyota did a good job on it. The only way to notice is when you see the regen gauge go higher and higher the more you hit the brake, especially at high(er) speeds, of course. Works fine for downhill speed regulation. In fact, you just drive and brake as needed.I have not yet driven an EV with regen on the brake pedal, but I am curious about it. Probably nice on level ground but not as good for downhill speed regulation. I did really like the adjustable regen on the paddle 'shifters' on the Ioniq 5 through when I drove my friends.
From an efficiency standpoint which pedals you use is irrelevant, it's HOW they are used.I would think the most efficient would be coasting and regen under the brake pedal.
If you can coast instead of regenerating to stop, you don’t have to convert the mechanical energy into electrical and back into mechanical to use. You just coast. There are losses associated with that change back and forth.From an efficiency standpoint which pedals you use is irrelevant, it's HOW they are used.
Can you "coast" with the Tesla by holding the pedal at the right position?If you can coast instead of regenerating to stop, you don’t have to convert the mechanical energy into electrical and back into mechanical to use. You just coast. There are losses associated with that change back and forth.
That’s all I’m referring to.
Not really... Think of the accelerator pedal as absolute energy output. When the energy output is higher than the energy required to maintain speed, you accelerate. When it is less, you decelerate. So, to coast like an automatic transmission, or manual with the clutch depressed, you have to carefully regulate pedal position, moving it slightly as the car decelerates to simulate that coasting.Can you "coast" with the Tesla by holding the pedal at the right position?
It doesn't really work in real life. You can't coast all the time. Just modulate accelerator and you get pretty close to coasting and when you need to slow down you save a lot with regen.If you can coast instead of regenerating to stop, you don’t have to convert the mechanical energy into electrical and back into mechanical to use. You just coast. There are losses associated with that change back and forth.
Kind of. You can modulate the pedal so the display doesn’t show any power or regen, but the pedal position to achieve that will vary depending on conditions and is also very sensitive so it’s difficult to maintain at 0.Can you "coast" with the Tesla by holding the pedal at the right position?
And how; when I take my foot of the accelerator in my wife's ICE car, it seems to speed up alarmingly, this perception is of course due to the subconscious expectation that we will slow down. It only took a couple of days of one pedal driving of the Tesla for this to manifest.Hard to describe, but it’s super weird.
It doesn’t work on a Tesla. I believe that’s how it works on Porsche.It doesn't really work in real life. You can't coast all the time. Just modulate accelerator and you get pretty close to coasting and when you need to slow down you save a lot with regen.
I set regen to Zero (via Track mode) and went the same route I normally go. I got 360Wh/mi with Zero regen instead of 260Wh/mi with regular default regen settings.
That's nonsensical. Coasting and doing nothing with kinetic energy yields nothing. Convert some of that to electrical to slow the vehicle, use the rest for charging.If you can coast instead of regenerating to stop, you don’t have to convert the mechanical energy into electrical and back into mechanical to use. You just coast. There are losses associated with that change back and forth.
What doesn't work on Tesla?It doesn’t work on a Tesla. I believe that’s how it works on Porsche.
Incorrect. Coasting uses that kinetic energy to continue to a stop. What’s the alternative, stop short, regen, and continue to the stopping point?That's nonsensical. Coasting and doing nothing with kinetic energy yields nothing. Convert some of that to electrical to slow the vehicle, use the rest for charging.
Regen when pressing the brake pedal.What doesn't work on Tesla?
