out of warranty, brakes need replaced
Discussion in 'Model S: Driving Dynamics' started by demundus, Feb 8, 2016.
  1. demundus
    demundus Active Member
    Oceanside, CA
    My brakes have been screeching lately as I come to a complete stop. I had first attributed this to low use (as many others experience on the forums), but today as I was rolling into my work parking lot I heard a steady metal on metal sound, reminiscent of.... worn brakes!
    1.) Can I do this myself? How? What pads do I buy?
    2.) If I can't do this myself, anyone have a cost guesstimate?
    I can't find any threads where anyone did their own brakes because everyone is under warranty around here, so any info is helpful.
  2. Skotty
    Skotty 2014 S P85 | 2020 3 P19"
    Kansas City, MO
    #2 Skotty, Feb 8, 2016
    I'd be surprised if any Tesla needed brake pads already. Someone with experience can pretty easily examine the brake pads to determine if they are worn to where they would need replacement.
    1) You should be able to do this yourself as easily as any other car I would think. But that's not to say it's simple. You should have someone there who has experience changing brake pads and bleeding brakes. Might be a challenge finding and getting to the brake master cylinder, assuming there is one (did Tesla do something non-standard here? surely not, but you never know); usually the master cylinder is under the hood in the engine bay, but since there isn't an engine bay, they must have hid it behind a panel somewhere.
    EDIT -- actually, you might not have to bleed the brakes (I've had to change out "cracked" front brake lines so many times, just thinking about brakes makes me think I'll have to bleed them), but you do have to be careful with the fluid level. As pads wear, service techs might put in more brake fluid; then when you put new pads on, you have to push the pad cylinders back in to fit the new pads and that can overflow the master cylinder, so you might have to siphon some out. But as long as you don't break the fluid lines anywhere and the fluid level never gets too low, you shouldn't have to bleed the brakes.
  3. demundus
    Oceanside, CA
    Very true, I'll be jacking the car up and looking myself, but for now I'm operating under the assumption I need them, as the screeching has been a presence for over a week and this new sound is pretty telling. My guess is its going to the SC, but trying to avoid $$ as best as possible.
  4. jaguar36
    jaguar36 Active Member
    NJ
    The brakes on a Tesla aren't anything special. Lots of regular (autozone)auto parts stores claim to carry pads that will fit. If you've ever changed the brakes on a car before it shouldn't be anything new to you. If not its a pretty simple job, but I'd watch some youtube videos first on how to do it.
  5. FlasherZ
    One word of advice... after doing it, be sure you pump the brakes to set the calipers and pads properly before rolling out of that garage while holding the door just open enough to pull the door frame off the garage. Not going to say how I know that. :)
  6. Skotty
    Kansas City, MO
    Good advice! Lots of people have had accidents immediately after brake service because either the brakes weren't pumped or bled properly. The former can lead to no braking at all on the first pump or two, and latter can lead to squishy feel and poor performance.
  7. Kalud
    Kalud Active Member
    Montreal, QC
    Maybe train your brain to think about the electric park brake just in case (hold Park button)
  8. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    last I checked on advance auto's website, the brake pads also fit the Camaro, a Jag, and a few other cars... I think even a Mazda.
    so yea, they are just normal pads. easy job. hour at most. I would like to know how many miles are on your S. thanks
  9. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I'd be surprised if your pads are worn out. I drive aggressively and at 40 K miles I've used maybe 15%. Check to see if perhaps you got a pebble wedged on the side of the pad. I've seen that happen and it makes the noise you describe.
  10. JayBoy
    JayBoy Member
    Raleigh, NC
    When I had 70,000 miles, I still had 6mm (out of 8mm, I think) left. I'll check again at 200,000!
  11. MsElectric
    MsElectric Active Member
    New York
    What brake pads does Tesla use? Where can you purchase OEM pads at a good price to make sure you don't end up with substandard pads? Will Tesla sell pads to you?
    How much would Tesla charge for replacing the brake pads?
  12. FlasherZ
    This is the same experience with another owner here in the St. Louis area. They had only 1 mm of brake pad loss (down from 9 to 8mm) after 65k miles. Perhaps low regen and aggressive stopping styles?
  13. Zextraterrestrial
    Humboldt/Los Altos
    I think the pads should be really really easy to replace.
    like 5 minutes per wheel, maybe a bit more to get the wheel off and back on than to replace the pad
  14. demundus
    Oceanside, CA
    73K and counting. Got a 80~ mile round trip daily commute
    Hah, I'll roll into a cement wall in my alley, RIP Tesla :(
    I would like to think the previous owner was gentle and knew what he was doing while driving but I can't be sure. Thus, my pads could be garbage, just need to get under and check to be sure. 73k with moderate to gentle driving on the highway would lead me down your path as well (i hope). I'll report back.
    I'm right around your mileage, we'll see what mine are.
  15. rogbmw
    rogbmw Member
    Central Florida
    You may have picked up a rock that lodged between the pad and rotor. Tesla front brakes do not have the shield on the inside as many cars do, so be sure to check that out.
  16. SabrToothSqrl
    PA
    I'm at 30,000 and I wonder if the inspection sheet shows pad depth... I'll see if it's in my mailbox.
  17. ifung90
    ifung90 Member
    hong kong
    no one has really answered OP's question ..
    Tesla Front calipers: Same as Mitsubishi Evo 8. Find any brake pads that fit the Evo 8 and you'll be fine.
    Tesla Rear calipers: 05-08 Cadillac CTS-V rear calipers. Find any brake pads that fit this model and you'll be fine.
    Recommendation that I know has replacements:
    1) Racingbrake.com CT500 brake pads
    2) Hawks have their HPS compound for both front and rear.
    3) Carbotech also have replacement pads for these two caliper types.
    Now depends on if you want an aggressive or everyday compound. Racingbrake is surprisingly bang for buck.
    If you're sick of the ****** brakes (without regen, they're garbage) then you can opt for an upgrade from Racingbrake to their bigger brake disc or brembo has full big brake kits available at $8000 for four.
  18. demundus
    Oceanside, CA
    Thank you!
    I haven't been able to take the wheels off... been sick. I will report back when I do.
  19. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Good lord what kind of braking power do you need to pay $8k for replacements on a 2012-2014 RWD S? I have to admit that I was very happy with my $75 per axle disc brake change (+ $50 for flushing and bleeding the fluid) on my ICE!
  20. jerry33
    Texas
    I think the $8k was for ceramic brakes.
