Cyclone
Cyclonic Member ((.oO))
I think the $8k was for ceramic brakes.
Ahhh. Aka, more aggressive driving than I would ever do, even with the "still works when hot" benefit of ceramic. Thanks! My S85 will be fine
What brake pads does Tesla use? Where can you purchase OEM pads at a good price to make sure you don't end up with substandard pads? Will Tesla sell pads to you?
How much would Tesla charge for replacing the brake pads?[/QUOTE
They are available on the aftermarket. Here is a listing on eBay;
Tesla Model s EBC Yellowstuff Brake Pads Front Set DP43028R | eBay
Although they are a bit expensive, they are available. I suspect that Tesla is using Mercedes brake components.
The design of the calipers should be instantly recognizable to anyone who's had Brembo brakes in the past. Tesla just used Brembo as their brake supplier. The pads are Brembos as well, right down to the slow initial bite when wet. There are likely dozens of cars with the same pads.What brake pads does Tesla use? Where can you purchase OEM pads at a good price to make sure you don't end up with substandard pads? Will Tesla sell pads to you?
Brake fluid resivor is on the drivers side right underneath the plastic cover at the base of the windshield.No one has brought up where the brake fluid reservoir is?
Could be. I was once tracking an Acura TSX I didn't own when a pebble got lodged in a pad. The sound was toe-curling, but I'm told the view was spectacular as sparks shot out 5' or so from my front wheel as I slammed the brakes coming off a straightaway. Track officials poked it with a stick and got it out after I limped to the pits. That rotor was probably toast. I'm glad it wasn't mine.Probably a pebble or other road debris caught in the caliper. Or you just need to replace the pad shims and add some anti-squeal compound.
I'd be surprised if your pads are worn out. I drive aggressively and at 40 K miles I've used maybe 15%. Check to see if perhaps you got a pebble wedged on the side of the pad. I've seen that happen and it makes the noise you describe.
Charged to an average of 90% during at least half of that time. Anything over 80%, and SvC said there's less/no regen. Aha! This, they said, puts the load upon the other set of calipers.
Something is really wrong, and I'm not sure it's with he rotors. Do you have traction control turned off? Frequent rotor changing is not a problem with the Model S. Pictures of the supposedly bad rotors would help.Pads are fine at 38,000 miles (1mm wear iirc from the annual service a couple of months ago), and tire wear is great (still a fair bit left) but I'm on my 5th set of rotors.
Brake pads are not under warranty. They are included under annual service.
