It's gone crazy since 4/1. I've had 2 auto-refills ($10 each) in the last two days!
Looks like you have been taken over by the Aliens
Can the V3 module be reset to factory conditions?
You don't need the Hologram connection for configuring the module; in fact, I don't think you can use the modem until the unit is configured. And note that it does not need to be hooked to the car to do so. Just a USB connection to a PC / Laptop for power, and use the built-in WiFi hotspot for configuring it with a web browser, or if you are more comfortable with a command-line shell, you can use PUTTY (or the like) to talk to it that way.Is there a "OVMS Installation for Dummies". Spent 4 hours this afternoon and at the end I was no closer getting it installed than when I started out. I thought I was following the installation steps, but somewhere along the lines everything goes to pot. The biggest issue is do I use the Hologram internet connection for the install or my home connection or do you have to go back and forth?
Best to set a data cap so this doesn't happen...
The usual cause is (a) firmware updates being configured over Cellular (defaults to not), (b) vehicle id / password incorrect (so server rejects authentication), or (c) very old firmware not backing off (like more modern firmware does). It could be something different, but those are the first things to check. Message me your vehicle ID, and I will look at what the server says.
One possible reason for high data usage is that you have a phone / tablet somewhere that is remaining connected to the OVMS app. That will keep the connection to the car open, getting live updates. Close the app and your usage should drop nearly to zero.
It also helps to keep the module connected to WiFi whenever it's at home, if your parking logistics allow that. The module should switch automatically between WiFi and Cell, preferring WiFi if it's available.
Who here uses Hologram? I've been getting charged $20 every 3 days...yes that's $200 a month. It was advertised as $20 per month when I signed up a year ago. Apparently it's through Tmobile. Any other options? I called to question the bill but haven't heard anything yet.
Yes, high data usage started in March.it looks like you might be having the same issue as me.
did the high data use start on 4/1? i've unplugged the OVMS for now.
i sent @markwj my vehicle ID and he was going to look at what kind of communications were happening to cause this.
the URL might be outdated. i think there is a new URL. i don't remember it though.
