TexasTeslaRacing
Not yet. I’ve been waiting 3 months for MPP coilovers. Hopefully they’ll arrive later this month.
I’m confused - you haven’t tried it but it works great?Not yet, but yes, it works great.
What size are you looking for? FYI VS forged has a similar wheel that is also fully forged, hubcentric and custom sizes/specs....and still cheaper than t-sportline with the 1K discount. You’ll have to wait 6-8 weeks....but keep in mind some of t-sportlines sizes are backordered.
cool I figured it was something like that. Thanks!Yes, it's great to know people with similar interests, and wheel/tire sizes. There are a few folks lowered at least an inch, and running the same setup, and they've had no issues.
Hello, where did you order VS forged from? I too was looking at the Tsportline wheels but they are really expensive. I want light weight 20 inch rims. Still deciding on squared or staggered. I could not find the weight of the VS forged wheels but the Tsportline ones are very light.
Cool, thx - so you went with a tiny bit less offset to gain a little clearance on the inside?Hi, it's me - guy with 19x9.5 and 265/35/R19 tires and a lowered car (UP coilovers) lol they work fine, i have a +33 offset but +35 would work fine and you can always use a 2mm spacer if you had to.
Looking at some TSW wheels they offer there specs
19x9 with +30
Or
19x8.5 with +40
Want to go with 245 40 19s Any thoughts on what will fit and look best?
I think 9" wide wheels are a no-brainer to get some more rubber/grip and also fill out the wheel wells for a better look, visually. A +30 offset will work out pretty well, i have +33 but with 9.5" wheels and 265 tires and don't have any issues with rubbing or excessive tire poke.
Comparing 245/40/19 +30 to my 265/35/19 +33 you get this (source):
Heres a photo of my set-up that i mention above:
II think 9" wide wheels are a no-brainer to get some more rubber/grip and also fill out the wheel wells for a better look, visually. A +30 offset will work out pretty well, i have +33 but with 9.5" wheels and 265 tires and don't have any issues with rubbing or excessive tire poke.
Nope the outer edge of the tire will be .28" further in AND the inner edge will be .52" further from the suspension on the inside, so no concerns about rubbing.
Basically the 245 tire will be about .8" narrower than what i have now with a slight position change from the +30 offset.
It's also worth mentioning that you are changing the scrub radius a little more which isn't great, but probably won't be too terrible with such a small change (5mm from stock).
Yea guess Speedo would be fast and put miles on the car fasfer. Are noticing a big range lose with those wide tires?
I plan to get 255mm or 10" on my 19" Tesla Wheels. (mostly to protect the wheels rim).I think 9" wide wheels are a no-brainer to get some more rubber/grip and also fill out the wheel wells for a better look, visually. A +30 offset will work out pretty well, i have +33 but with 9.5" wheels and 265 tires and don't have any issues with rubbing or excessive tire poke.
