Xenoilphobe
Anybody know what the DOT wheel loads are for Flow One Wheels?
- There are no government standards or regulations that require a wheel manufacturer or importer to meet in order to sell a wheel in the US. There are several marking and dimensional requirements that are required by the DOT (Dept. Of Transportation), but no performance or testing requirements.
- The standards for performance and testing are voluntary on the part of the manufacturer or importer. There are several specifications that are considered recommended practice, available from such organizations as SAE (Society of Automotive Engineers), TUV (the German regulatory agency), ISO (International Standards Organization), and JWL (Japan Light Alloy Wheel Testing Council Rules). The SAE J2530 Aftermarket Wheel Performance Requirements and Test Procedures is a new standard developed for the aftermarket wheel industry to assure that the wheels produced for use on passenger cars and light trucks are safe and reliable.
- The testing requirements of J2530 are composed of 3 performance tests.
- The first is a Dynamic Cornering Fatigue Test. This is a test that simulates the forces of load put on a wheel when the vehicle is turning a corner or going around a curve.
- The second is a Dynamic Radial Fatigue Test. This is a test that simulates the forces of load that the wheel experiences with a tire mounted and carrying the weight of the vehicle, passengers and or cargo.
- The third is an Impact Test. This is a test designed to test the effect on the wheel in the event of an impact to the wheel such as hitting a pot hole or side impact into a curb.
- The quantity of wheels required to complete the testing are as follows:
- Cornering Fatigue = 2 up to 7
- Radial Fatigue = 2 up to 7
- Impact = 2
- Marking requirements:
The markings that are required by DOT are as follows;- Wheel Load – this is the maximum load that the wheel is designed to carry. The wheel load is determined by taking 50% of the heaviest axle rating of the vehicle (GAWR – gross axle weight rating). Example; if your heaviest axle weight rating is 3000 lbs then your wheel load requirement would be 1500 lbs.
- Wheel size (example 15×8).
- Wheel manufactures name, trademark or symbol.
- Date of manufacture of the wheel, indicating month and year.
- Manufacturers part number or code.
- Country of manufacturer.
- The symbol “DOT” constituting a certification by the manufacturer of the rim that the rim complies with all applicable vehicle safety standards.
- Here is a simple way to determine what a safe wheel load rating should be for your vehicle.
- The first thing to do is check to see if the vehicle has the original data plaque. Normally it can be found in the door jam or door on the driver’s side.
- If that isn’t available then use the following rule of thumb;
Passenger cars (not including stretch limo’s) = 1400 lbs
Pick Up trucks – bolt patterns 5×4.50” & 5×4.75” = 1600 lbs
Pick Up trucks – bolt pattern 5×5.00” = 1900 lbs
Pick Up trucks – bolt patterns 5×5.50” & 6×5.50” = 2100 lbs
Pick Up trucks – 8 lugs = 3400 lbs
