SammichLover
Banned
*facepalm* "Continued reading fail alert".Yes, I see that. As I clarified above - yes, that is flat for the AWD, but not related to electric motors - it's due to the AWD software limitation.
*facepalm* "Continued reading fail alert".![]()
I'd be entirely unsurprised if the instrumentation didn't operate down there in an any meaningful way, and even if it did the software probably isn't set up to react and treat the info in that small window as relevant and likely throws out that data.
Oh come on. Look, nobody is denying that it's possible Tesla is using rollout for some models and not for others. But you said Tesla EXPLICITLY said they are.
I think you're using the word dishonest incorrectly. Just one opinion.
For what it's worth, there are HP calculators out there.
Engine Horsepower Calculator
Determine your car's weight and then look up the best quarter-mile drag strip run for that same car, enter the data and it will give you a very close estimate.
I mean- you've been shown Tesla.com saying exactly that
Then also shown both Tesla.coms own change from 3.5 to 3.3 without any actual change to the car or software when they switch the P3 from honest reporting to the same "rollout for one but not the other" system they've been using on the S for years.
Then also shown calibrated testing data of the 0-60 times on the P3D and the LR AWD proving exactly that is what's happening.
Here's 3 runs above 85% SOC. The gains are there and I was able to do more runs (than those attached) at under 3.2 seconds (if you count roll-out).
The original quote from @MoreAgain made it clear there was a software limitation to contrast between P and AWD. Which is correct. All I was pointing out (since it got a bit confused in the follow-up post) is that the flat area between 50mph and 100mph wasn't due to electric motors (which you could argue was implied in that subsequent post).
Wrong.
It is an entirely normal thing to see in electric motors with fixed power input (a choice in operating, not a "software limitation"), and an entirely abnormal thing to see in an ICE engine. Because of the nature of electric motors, which have a very wide RPM band of near-optimal operating in contrast to ICE motors.
Do you happen to have any data from the same vehicle on the same course at the same weight at high SOC before the update? Could look at the splits and do some simple math to see if the peak torque increased. It kind of looks to me like the torque is simply sustained to a higher speed, and the results sort of imply that as well (it's not that much faster...but that's why I was curious about comparative data from your car, since that relatively slow time could just be due to junk in the trunk)
10-40mph looks like about 1.61-1.64 seconds here. Wonder what it was before for your car... (on my car with the prior update, I got 1.58 seconds 10-40mph at sea level)
But, your 40-60mph is about 1.26-1.28s...whereas with the prior update my 40-60mph was 1.32s. So that is a LOT faster than mine (though mine was kind of a dog in that region from what I recall possibly due to battery temperature).
So if that data pattern holds, this looks more like peak power increase than a peak torque increase. You'd have to have a few runs with the prior update in the same conditions to really know. So many variables.
Man why are you always on here arguing with people?![]()
Haha. @Knightshade is right about brakes and right about 1 foot rollout and I admire his tenacity in correcting everyone who spreads misinformation about the subjects.I dare you to ask him about brakes and stopping power...a 2 inch by 2 inch rotor/pads will stop a car as fast as 14 inch brembo's if they had the same tire size hehehe.
Too many variables, honestly. I don't have a strip that I might reliably test on and even then there's a lot of other variables.
Attached is an image from when I had V9. I basically could get these figures repeatably so I kept this as a record.
It seems like you are always engaged in some sort of "debate" on here. You must enjoy confrontationsI'm not the one arguing.
I've simply stated the same documented facts a bunch of folks before me mentioned about how Tesla misrepresents the P versus non-P performance differences.
It's other folks who seem to want to "argue" about if these facts are facts (they are- as cited by screenshots from tesla themselves, and then confirmed by numerous calibrated measurements from both owners and car magazines)... and then when that argument fell apart they now want to argue if this dishonest is "important" or not.
It seems like you are always engaged in some sort of "debate" on here. You must enjoy confrontations![]()
I
For the record, I do agree with your stand on most things. Including the testing inconsistencies for Performance vs Non-Performance. But I'll be honest, the way you talk sometimes comes across as a bit pompous and condescending. I'm sure your intentions are good but it might be rubbing people the wrong way. But hey, I'm not here to tell you how to act. You do you bud.
(see the dude in this very thread who kept insisting he still isn't actually convinced Tesla uses rollout on the published P numbers despite a mountain of evidence they do including from Teslas own mouth)
