Hacking up, or jacking up?
Woops, jacking, haha!
On my NASA GTS-4 BMW E46 M3 I run a full cage with bucket seats, six-point harness, and HANS.
On my BMW F80 M3 I ran bucket seats with Schroth Quick-Fits and HANS.
I agree, there is definitely a better setup than stock belt with no HANS. The airbags would be impossible to swap, but easy to trick. The occupancy sensor you could likely swap over. It just starts to affect the comfort/usability of the car.
Alternatively, this hybrid exists, which appears to work with the stock belt: Hybrid Sport: Simpson Race Products
Interesting- is the purpose to give you HANS protection without a harness?
I was thinking of putting a race seat and harness in but did a bunch of research and found lots of conflicting info, but consensus (as much as it exists) among folks who would seem to know was that seat/harness/HANS without a cage is a bad idea (getting smashed like an upright bug if the roof collapses in a rollover) and there’s no way I’m putting a cage in a street/track car, personally. If I get serious enough about track driving i’ll probably buy a dedicated track car. Shame because I enjoy driving the 3 on the track quite a bit.
Word.To me, the best you can do is go into it with eyes open that your safety is entirely up to you and your personal level of comfort.
Good conversation regarding safety. I think it really comes down the Model 3 being already quite safe with the stock system and robust in a rollover, which is very unlikely anyway. Sticking with the stock system and adding a Hybrid HANS-type device is the best bet unless you are building an all-out race car with a cage (which I don't see happening any time soon).
I wanted to show off my alignment specs. Something else I haven't yet shared is my prototype front upper control arms with offset bushings. As you can see, I was able to gain an additional 1.5 degrees of negative front camber after lowering it, bringing me to a total of 3 degrees of negative front camber. I also included some better photos of the rear control arms and you can see the Ground Control weight jacker kit (which literally means adjusting the rear suspension up and down takes a 17mm socket on a wrench).
Ooh nice. A couple questions:
- what is the effect of front toe out? Does the car tramline on the road? I like sensitive steering with near zero toe, but toe out is usually too much for me on other cars. Yet I see the M3 has a stock toe range including toe out! Wondering about steering dynamics.
- does the car tend to push? +2 degree negative front camber vs rear should counter it if so... and since its high power AWD, wondering if a little push is OK? Maybe you'd trail brake and then get on the throttle really early after apex to bring the front around?
(Side note - the pushiest car I ever drove was a Yugo in a Lemons race on Walmart tires. It would start to slide at 25mph in a corner. The only way to drive it fast was to give it more throttle when it started to push. It would still understeer, but it would also bring the front around. Totally counter to normal weight transfer strategy. We were also totally destroying tires!)
- how sensitive is handling to ride height differential front to rear? My Miata is extremely sensitive to ride height changes, to the degree that 1/4" change in front ride height can make the car tail happy vs neutral. But the M3 is way heavier, so not sure if it would be as dramatic?
- how neutral is the car as stock?
That's expected for Hawk pads, they suck, only acceptable on light cars that don't need much brakes.
Raybestos/Porterfield pads are great for heavy cars, originally designed for nascar back in the day. Caveat is that even their st-43 is way too aggressive for a light car like a miata.
My current plan is to grab the girodisc rotors from mountainpass, and then send a brand new set of pads to raybestos/porterfield for them to measure and make the custom size, very affordable. They are a traditional race shop like coleman racing, so horrible website, but if you give them a ring they take care of you. Wendy at porterfield really knows her stuff, schooled me a few times on friction compound splits between axle's and why my great idea is actually terrible, lol.
How are you charging up at the track? RV 50amp?
How long are the sessions, how much % do you drain, how much % do you can back charging between sessions?
What's the event there? I don't see it on their websiteNovember 1st-3rd @ VIR.
Great info and video, thank you for posting. How did you capture your braking data?It took me a while to gather all the data/upload video/etc from Hyperfest last weekend
What wheels and tires (size?) were you using during this trip? What rear rotors are you currently using?Street Analysis:
The new aero and suspension has resulted in a roughly 17% increase in efficiency based on my own data. I took a trip today and recorded the following:
Miles Driven: 50
Average Speed: 74.88mph
Wh/Mi: 255
Ambient Temp: 95f
HVAC: A/C On, 75f
Before, I was averaging around 300Wh/Mi with the HVAC OFF at 75MPH.
So, certainly a noticeable and rather staggering improvement!
