No but the amount of boost and fuel pressure and fuel pump capacity does matter as does the intake and the exhaust all of which ICE manufacturers must bolt to the engine before they run it on a brake horsepower dyno. Manufactures only specify the power that their iCE makes in it's current configuration. There are many crate motors that make wildly different amounts of horsepower depending on what you attach to them. Motors that have turbos have very large differences depending on what boost you run them at and how rich you're willing to map your air fuel ratio under load to prevent pinging/detonation.
Manufacturers never specify horsepower based on what their engine could make but only what it does make as it is configured in that particular vehicle. Haven't I already said all of this before? Like a million times by now?
But in the end, it comes down to how much horsepower is actually made. Notice how the hp numbers jumped up a lot for the Ludicrous mode? They're not displaying combined power of course because doing that is what started these stupid debates, but if what you said was true, then how come they've suddenly change those numbers? If the previous numbers are what the motors *could* make if you gave them enough food, then how come their now saying it's a whole lot more. It means the previous numbers weren't the actual maximum potential of those motors despite their diet.
Oh, yes you can. He chose to talk about what could be done to a Supra, and how its maker ethically advertised only its as-delivered HP. We could be talking about the thrust of a unicorn passing skittles. The same ethic applies. Anything more is fictional.
I can buy an LS7 crate engine from Chevy. It is rated at 505 hp, and I can pretty much use a standard gas tank and fuel pump and get that 505 hp.
http://www.chevrolet.com/performance/crate-engines/ls7.html
For an EV, I can buy a AC-150, 150kW (201hp) motor from AC Propulsion. However, if I put it in a Leaf, I will never see 200 hp because the battery is limited to ~80kW (110hp).
https://www.acpropulsion.com/datasheet/AC-150 Motor.pdf
That is the main point I am making. With "motor power", Tesla is advertising the "200hp" "motor power" number above as opposed to the 110hp system horsepower number. And if you see below I have an example of where they have both numbers.
On the subject of increased numbers for the P85D "motor power", it is possible Tesla made some changes to the motor or that after adding the fuses they found that the motors can be pushed further than expected. The way motors are power limited is by how much tolerance they have for operating in higher temperatures (there is a good thread on the Roadster software that showed the limits for the Roadster motors). It is possible to push these thermal limits at the cost of operating life of the motor. It may be possible that given Elon mentioned the new fuse and inconel contactors operate much cooler than before, they can operate at higher current without overheating the motor. Or they have made some changes to the production versions with the release of P90D.
I'll refer you guys to this again about the two numbers being advertised at the same time:
I'll use another example with the Swedish site. Now looking at the website closely, there is actually two different power ratings for every single model (P85D excepted, as brian pointed out):
85D: 422 hp, 262 hp front and rear motor power
70D: 332 hp, 262 hp front and rear motor power
S85: 378 hp, 388 hp motor power
S70: 320 hp, 388 hp motor power
http://www.teslamotors.com/sv_SE/models
How do you guys explain what "motor power" means in the above example (for example 388 hp motor power for S70) vs the first number (320hp for S70)?
