Yeah, I have just left mine on both range and insane since .139 came out.
I still would like more detail from tesla on range mode. It reduces HVAC energy use. It's also been rumored that I changes the thresholds for pack heating and cooling. Ok, at the sacrifice of what? Battery life? There has to be a downside, otherwise there would be no need for range mode.
Nope, I meant range mode.
Tesla gives us a toggle: range mode on or off. Why?
For one, it reduces the energy used for cabin heat and cooling. If you're not trying to get the most range, then you're fine using more energy for comfort. This makes sense. But if this was the only thing range mode did, why call it "range mode"? Why not just call it climate Econ mode, which it just so happens is what the UI displays when range mode is on and is a term used by other cars.
Because tesla chose not to do this, we can infer that range mode does other things. What are they? We believe it changes the thresholds on when the BMS will start to heat or cool the battery pack. We do know that range mode on the roadster behaves this way. If there was no downside to more extreme temperature thresholds, then there would be no need to give the user a toggle. Just use the more tolerant settings all the time. But tesla choose to expose range mode in the UI. Which means there has to be a downside, and my guess is it is battery capacity/longevity.
With respect to the P85D, tesla has said that torque sleep is active all the time, but that it will be most effective with range mode on. Why? What else does it change?
Does that make sense?
I'd really like a more detailed explanation on what range mode does on the model S so that I can make an informed choice on when to use it. Turn the question around: what am I sacrificing if I chose to leave range mode on all the time?
Andrew
1. It limits the power used by the HVAC.
2. It limits battery heating to the minimum amount necessary. This is fairly easy to show on two days when the temperature where the car is parked is around freezing. On one day set the charge to end about when you're going to leave, turn on range mode and note where the regen limiting yellow line is. On the other day, turn off range mode and note the line. There is a significant difference on my car.
So we agree that range mode changes the temperature tolerances before active heating and cooling turn on. An effect of this is that regen and max power will be reduced for a longer period of time, and for short trips, the limits may never be lifted.
So with range mode off, I'm sacrificing some range to have a more consistent user experience and increased performance.
Is that it? I'm betting no.
Alright everyone, I've uploaded some more data to the spreadsheet based on the 4 legs of my latest trip to Tahoe now that I'm on 2.2.179.
Results: slightly worse than previous torque sleep versions (.139, 140, and 167) but still way better than pre-torque sleep.
My theory is that Tesla cut back some of the torque sleep conditions in .179 to avoid the dreaded loss of power messages we were getting on .167.
See this thread for more details: P85D Lost power on road,
I want to get more consistent with how I measure for next week's trip of ~500miles (maybe 1500). Is there a recommendation for the way people measure? Eg. Avg speed (run a timer?), elevation change (evtripplanner?), etc?
Thanks, Mike
Here's what all you cold weather suckers have to look forward to in your P85D when the weather warms up![]()
I did a full range charge at the Baton Rouge Supercharger before returning (arrived there with 29 Rated Miles remaining).
I thought the general consensus was that frequent range charges or range charging and letting the car sit at 100% SOC (or close to that) was bad for the battery.I thought the general consensus was to only range charge when needed, because range charges were bad for the battery.
Just wondering why you chose to do a full range charge since you didn't need close to that much range to make it back. I thought the general consensus was to only range charge when needed, because range charges were bad for the battery.
Thanks again for the report!
Second, as to why the range charge:
1. Because I was going to immediately burn it off when I departed the supercharger
2. Because I was the only one there (no one waiting to charge)
3. Because I had the time
The general consensus here may be that range charges are bad for the battery but I don't necessarily buy into that. I do buy into not letting the battery sit for extended periods of time at a full charge nor a very low charge. I charge to 90% every time I charge (have always done that and did not see any discernible degradation of battery capacity in the 18 months of previous ownership). I don't believe the occasional charge to full does any harm whatsoever to the battery.
Mike
