dennis
Model S Plaid
Those numbers make the PD a truly usable car and certainly remove any regrets I had when I first took delivery.
In Tesla we trust. :biggrin:
Thanks much for the throttle sensitivity confirmation......
I now have 140 and it seems to be much better at TS than 139. I'm seeing much lower energy usage in my overall driving (city, mixed and highway) than before.
Also, as rays427 pointed out, rain seems to make a difference. This was pre torque sleep but I drove about back from Delaware (130 miles) in a heavy rain storm in January and used significantly more energy than my trip on the way out. I think rain is worse than a headwind!
As one of the people not seeing improvement with .139, I'm very happy to hear this.
When did you receive .140? If you received it recently, I think you'll be the first to have reported having received it in the past few days.
Edit: I just saw that the service center installed it for you a couple of days ago, so there's nothing those of us waiting for it via OTA update can infer from your having received it.
I received .140 yesterday.As one of the people not seeing improvement with .139, I'm very happy to hear this.
I spoke with Tesla tech support today, to alert them to the fact that I was not seeing the torque sleep efficiency improvements, and to see if they could pull my logs to see if torque sleep was actually working on my car.
So, were they able to tell you anything on your particular car?
Not yet. The logs did not show up immediately. I'm waiting to hear back.
What I would like to know is why this breakdown of energy usage isn't available on my center screen...
Andy:
I have noticed that many of the P85D owners who see significant TS gains in Wh/m efficiency seem to be in warmer climates with FLAT terrain.
Now, I am not probably too far off in saying your environment is perhaps just the opposite of warm and flat. Probably cold, snowy and undulating at least.
I suspect if you were where they are and they were where you are.... (Gee did I actually type that?)... then they would be sending your letter to TM....
What is the typical temps up in Ithaca bout now? 15 to 20 degrees?
Did you by chance get to read the latest Tesla Living blog entry on cold weather and Wh/m? Sobering...
Andy, I assume all this means you still have not seen any significant improvement in energy consumption?
As far as using more energy in the cold - of course that's true but I would think you would still seem a similar percentage improvement (if you were using 500 Wh/mi in the cold before TS then I'd think you'd see 450 Wh/mi after if all was working properly). Aren't there others in similar cold/terrain that have seen improvement?
Mike
Andy:
I may have been confusing in my previous post.
I do think TS works in cold weather.
I do think TS works not as well in undulating terrain where you are going up and thus demanding torque.
Those S driven in flat terrain have the luxury of attaining speed and then essentially coasting.
Here in New England and where you are, that is not the case. We have every present ups and downs.
Now back to the cold... from what I have been reading, heat and heated seats do consume quite a bit of power.
Also in deep cold, I here that regen is mitigated and at the worse case totally non-funtional until the battery pack
is up to 45 degrees or more (from what I have read).
So I think it is plausible that any savings that TS is giving you is being consumed by heating, seat heaters, defrosters and also perhaps heating the battery pack. And if there is wet roads or snow on them, then that can really put the kebosh on efficiency.
I hope you can find the Tesla Living blog.
Tesla Living
My basis for claiming that I'm not seeing the torque sleep efficiency is the benchmarking against EV Trip Planner. I'm consistently right around 5% above what EV Trip Planner would estimate, give or take a little bit. Others who have seen efficiency improvements are beating EV Trip Planner estimates by 10% or so.
This means nothing conclusive unless all other things are equal, which they aren't. The most likely cause for this is that EV Trip Planner has some systemic error in your situation, like maybe your tires are under inflated (a simple example that is not likely the case). To eliminate that possibility compare your car with another car (that saw an improvement when torque sleep appeared) doing the same exact trip at the same time. If your energy usage is worse than theirs then there's likely a problem with your car. But even so it could be something as simple as under inflated tires.
I think Andy drives too fast! In my experience, torque sleep is hardly used at 75+. I currently have 2k miles on my P85D, @ 367 wh/mile, my lifetime on my old P85 was 360 wh/mile after 16k miles. (Just for comparison, my lifetime with my S85 was 355 wh/mile with 6k miles.)
