Your driving habits really push the wh/mi really high. Is your regen set to Standard or Low?
Set to low, like it cruises...
Set to low, like it cruises... I just plugged yesterday to charge 100%... it was 90%... today morning still 99% and saying 35 min to charge... so in 12 hrs basically to charge 10% and it didn't... pretty sure my battery is ****ed up since day 1... too discrepant compared to LR RWD... i know are two different apples, but still.
What's your wh/mi lifetime? And average now that we are on the summer?
I think you're taking that % indicator way too seriously... there's no way to actually know the % charge of a Lith-Ion battery. It's an estimate based on voltage behavior while charging.
The only way to REALLY know precisely how much energy can be drawn from a lithium ion battery is to actually drain it to whatever your voltage cut-off is, and track what you've drawn along the way.
Everything else is an estimate. Your car is estimating the battery based on observations. Sometimes your % can actually go UP while the car sits parked. I've seen it go up 3-5%. Sometimes the % can drop more than you expect, because the battery is basically saying "yeah, what I told you earlier, that was wrong."
Anyway, the % is an estimate. The consumed wh/mile is a lot more trustworthy.
Having Regen set to low and then letting the car "coast" like that will absolutely kill your efficiency. Set your regen to standard and if you want to coast adjust your positioning of the accelerator pedal to the "neutral" spot to let it coast. (Or shift into Neutral.)
Just let it sit charging to 100%, it helps "balance the pack" just make sure you use it up quickly so it doesn't sit there. Also your Wh/mi would probably improve a lot if you set it to standard regen. For reference my lifetime is 275 Wh/mile and with the 24.4 update I'm now regularly getting 260 Wh/mi (stock 20" wheels/tires).
Regen doesn't work that way. Converting electrical energy from the battery to mechanical and back to electrical involves conversion losses. Each way is about 80% efficient, so that regenerated energy is ~64% efficient compared to where you started. So press the pedal to avoid the green line and the black line, and you'll be at peak efficiency.seems like the regen was getting back a lot of the energy... and I have read, regen can be responsible to up to 20-30% of the range? is that true folks?
Yea will be draining and checking it now carefully on Chill Mode and will set regen to standard now, but I think Alan told me that Low would be better cause either way the Standard would be "braking" somehow.. and then you are not coasting since you need to find the optimal pedal acceleration... but yea with my previous M3 LR RWD I always had set on Standard Regen and seems like the regen was getting back a lot of the energy... and I have read, regen can be responsible to up to 20-30% of the range? is that true folks?
Will do now after 11k miles low regen... hope that helps. Thanks man! 275 is great! mine 321 sucks... 260 even better... can't even complain. Whats your aveerage mph since you are close to me, I can't keep up on 57, 60 freeway at 70 mph.. always need to go 75-80 ... mine is also 24.4 now.... didn;t notice big difference on efficiency.
Thanks and I have tried this on Jan/Feb thanks for reminding it and will try again. May I ask which model 3 you have?
I understand that because I had with PUP it came with 20” wheels summer tires I think, bigger brakes... and this the main factor from what I understood, and some excel sheet I saw around says that would drop range from 310 to 265... which I would be happy to have.
But i checked my lifetime wh/mi and it is 321 wh/mi... which is about 233 miles range considering a 75kw battery, but that’s average and it doesn’t tell much.
I will have to start tracking it maybe using apps to help. Just really dont like idea of 3rd apps accessing it. And not even sure if Tesla would accept arguments based on 3rd party apps... anyone been through that in the past with model s or x?
Chill doesn't impact your range that much TBH and I never turn it on. Its more to protect drivers who don't understand the power behind the car from going too fast too quickly.
Here's my typical route, I run autopilot most of the way adjusting between 65-75 mph most of the time. I'll accelerate as much as 80-90 mph at times but the average is pretty bad due to traffic. Typically 40-50 minutes for a 30 mile commute averaging 40-50 mph with a couple of stretches at 70-80.
There's no way a p3d is going to get 300 miles when driven typically. That is an EPA test result for the AWD model, which comes with low friction tires, not sticky PS4 michelins.
Whatever loophole allows Tesla to claim results for the p3d that don't match what it would get as-sold needs to be closed
Actually Tesla rates the mileage lower than the EPA tests for all of their cars. I admit that I am no tire expert, so I will concede that the tires could cause a range drop. That might also be why you can now get a P3D with regular wheels. I hear those low profile tires are prone to blowout and a bitch to find if you have one so I wouldn't want them on my car to begin with. Then again, I'm not planning to head to the track either.
I have a Standard Plus with 18" aero wheels. Looking at the 20" wheels that Tesla uses, they seem to run very low profile tires. In fact the ride height is slightly lower (.5 in.) with the 20 inch wheels than the stock 17" wheels as long as you are on stock tires. I really can't see how that would affect your range that much. Make sure your re-gen is set to high (which you will learn to love if you stick with it for a week or two)
I really want to know how many miles your car says it has left when you battery is at 15% charge. That will tell you very accurately what your true range is.
I did some research and based on statistics I'm seeing you should be getting an average of 293 miles.
That is with an average of 500 lbs of cargo and 2% calculated battery degradation at 80°F Average speed of 65 mph.
These stats are from actual M3 performance owners. Unless you are in a much colder climate or regularly making massive altitude changes, these numbers should be fairly close for you as well.
For what it's worth, my average Wh/mi is: 263 So just a smidgen under 20% difference.
My car has a 60kw battery and I easily get the advertised 240 miles.
