I’m going to have to quibble just a little with this. I believe your numbers, but I disagree that you are getting the “advertised” range (it will be interesting to get the report back from
@Ticobird after he finishes his Alabama trip).
The range is relevant for a speed close to highway speeds - say about 60-65mph. People expect to be able to travel ~300 miles at this speed on a full charge.
You would never be able to do this with a P3D with PS4S, while you can if you have MXM4s, that is my disagreement here. The tires make a massive difference.
You can’t get the advertised range with the PS4S.
So what is your average speed over 68 miles? (How long does the journey take?). It sounds like 45mph. That is quite slow and you have minimal aero losses, so if you were getting the advertised range you should be doing
much better than 250Wh/mi. As a point of reference, my brother’s P3D with MXM4s (see above) did 247Wh/mi at an average speed of 68mph. That is way, way better than you. He can
actually get very close to the advertised range in his P3D. He also had aeros on which helps a bit.
You would do much better with MXM4s for this journey and in general even without aero covers.
I don’t blame the car, I blame the tires. (Which are awesome tires by the way, and considerably better than the MXM4s in other ways).
I will finally get a chance to drive from San Diego to LA this week and do a long, flat trip at moderate freeway speeds (70-80mph, maybe slower, but with traffic so some drafting). I fully expect to see worse results than my brother even though my average speed will likely be lower.
The best I have done before on a long trip is 260Wh/mi-270Wh/mi - but that was not on freeways - so closer to 50mph average speed on moderately twisting rural county roads - with over 5000 feet cumulative elevation gain (zero net gain). So one factor was positive and one factor negative. Might have been similar to your 250Wh/mi at 50mph average speed if it had been flat and straight.
Anyway I will report sometime this week.
