Mockingbird
source?The real reason for separating out the DC pins on CCS is to make it so clunky that it stops EV adoption.
Apologies, I was generalizing. Yes, I realize that the super chargers have a switchboard and a separate cabinet for managing multiple charging stations. It’s a better system than what EA have been using and other systems which have built in screens as well as no centralized load balancing. The lighter weight plug is proprietary and is a better/mechanically sound design than CCS1 and CCS2 in my opinion. The reason why I say the Supercharger designs are cheaper is because each station is just a cable with only 1 button. The rest of the functionality is through the charging cabinet and the app. There are fewer parts and the charging load can be balanced across multiple charge stations. The supercharger cabinet is also more easily serviceable and redundancy can be set up. A lot of CCS chargers require a separate computing unit, screens/buttons, and also integrated payment systems. I also think that the reason why you can’t get higher kW charging is due to load balancing and peak energy ability from the transformer.You don't know what you are talking about.
Most of the "charger" is a giant cabinet hidden somewhere and what you plug into your car is just a dispenser.
The real reason for separating out the DC pins on CCS is to make it so clunky that it stops EV adoption. The committee on this consisted mostly of car makers. They make money on ICE cars and lose money on EVs. ICE executives are not paid to shoot themselves in the foot by paving the way for EVs Ever wondered why ICE-maker EVs have two to three manual charge covers per port while Tesla has one automatic? It ain’t to make charging easier…
edit: the clearest example is Europe where Tesla had already combined integrated the DC pins into the already standardized type 2, 1 to 3 phase connector which then doubled as Tesla supercharger connector. Type became the CCS2 top half with the DC pins moved out. it’s clear as night and day how a beautiful plug that worked was deliberate turned into something ugly that barely works.
J1772 and CCS1 is the most sucky "standard" and both need to die. That 5" long latch on the connector is a weak spot, and breaks frequently, and it doesn't support 3 phase. We need a new standard that supports 3 phase AC and DC charging with 2 of the AC pins in a larger form factor and shared with DC, kind of like the TPC has. Basically, a TPC with 2 additional AC pins for 3 phase support. It would be worth dumping the TPC in exchange for that, but it's definitely not worth dumping it in exchange for J1772/CCS1.CCS makes more sense vs Tesla plug. Yes Tesla was first but the market needs one standard. CCS is better for consumers because you don't need a J1772 adapter as does Tesla.
What did you just write? You need a padlock? So it is usually true what I wrote. You do need a 3rd party part and then you write its not usually true. Huh?This is usually not true. Most J1772 handles have a small hole in the release latch that is made to fit a luggage padlock. That way you can physically lock the J1772 handle to the adapter, which is locked to the car.
Source of breaks frequently?J1772 and CCS1 is the most sucky "standard" and both need to die. That 5" long latch on the connector is a weak spot, and breaks frequently, and it doesn't support 3 phase. We need a new standard that supports 3 phase AC and DC charging with 2 of the AC pins in a larger form factor and shared with DC, kind of like the TPC has. Basically, a TPC with 2 additional AC pins for 3 phase support. It would be worth dumping the TPC in exchange for that, but it's definitely not worth dumping it in exchange for J1772/CCS1.
1+. What you describe is almost what Tesla used as supercharger connector in Europe until CCS combo 2 was mandated. With the difference that up to four AC pins where utilized in DC mode.J1772 and CCS1 is the most sucky "standard" and both need to die. That 5" long latch on the connector is a weak spot, and breaks frequently, and it doesn't support 3 phase. We need a new standard that supports 3 phase AC and DC charging with 2 of the AC pins in a larger form factor and shared with DC, kind of like the TPC has. Basically, a TPC with 2 additional AC pins for 3 phase support. It would be worth dumping the TPC in exchange for that, but it's definitely not worth dumping it in exchange for J1772/CCS1.
Okay, sure, you are correct: you need a "3rd party part" that costs less than $5 at a drug store. Apologies for thinking that your statement implied that this was not possible without some fancy equipment that you needed to order from a specialty shop.What did you just write? You need a padlock? So it is usually true what I wrote. You do need a 3rd party part and then you write its not usually true. Huh?
The latches I frequently see broken on local Chargepoint EVSEs.Source of breaks frequently?
I have seen Tesla plugs with broken pins and some laying on the ground, supposedly a signal they are broken. I don't promote that as a generalization that many Tesla plugs are prone to breakage. I have seen flat tires too on Bridgestone but don't generalize Bridgestone tires get more flats than Michelin.The latches I frequently see broken on local Chargepoint EVSEs.
You can be snarky all you want but my point still stands. With CCS due to commonality with J1772, absolutely no adapters needed. With Tesla, I need a) J1772 adapter and b) an additional lock to secure things. What fun in the rain and if you snow and ice.Okay, sure, you are correct: you need a "3rd party part" that costs less than $5 at a drug store. Apologies for thinking that your statement implied that this was not possible without some fancy equipment that you needed to order from a specialty shop.
This is dumb. Why have Tesla nozzle as the standard when CCS is already the standard for every other OEM? This petition make no sense to meThis would be awesome!
Sign the Petition
Congress: Tesla Superchargers and Plugs should be the Uâ.âS. standard for EVswww.change.org
Aptera asks Congress to make Tesla's plug and Superchargers the standard for EVs in the US
Aptera has launched a petition to ask Congress to make Tesla Superchargers and its plug the standard for electric vehicles...electrek.co
I signed the petition. While I realize it's somewhat unlikely to pass I just want to stand up for what's right.
...and also the fact that it was started by ApteraThis is dumb. Why have Tesla nozzle as the standard when CCS is already the standard for every other OEM? This petition make no sense to me
never seen a broken Tesla connector and never had any Tesla charging adapters fail.
...because Tesla's terms of use for the Tesla Proprietary Connector (TPC) are unacceptable to most automakersWhy would you lobby for the most expensive option? It would cost a lot more to change all the Tesla connectors to CCS than change the CC to Tesla.
