Pics of 21" Wheels with Coil Suspension?
Discussion in 'Model S: Interior & Exterior' started by Dreamin, Sep 14, 2013.
  1. Dreamin
    Dreamin Member
    SoCal
    I have a coil suspension and am looking to upgrade my 19" wheels. I'm concerned about the fender gap (space between top of tire and bottom of fender lip) if I get 20" or 21" wheels as the air suspension sits lower than the coil suspension (in normal and low settings). And all the 21" wheels pics i've seen obviously have the air suspension...
    Anyone have 21" wheels on a coil suspension car and can you please post pics.
  2. wycolo
    wycolo Active Member
    WA & WY
    'Upgrade'?? It is only possible to downgrade the 19 inch wheels. :smile:
  3. Shumdit
    Shumdit Member
    SC
    P85+ got my vote (both with my heart and my wallet)
  4. Atlantian
    Atlantian Member
    Orange County, CA
  5. rjcbox
    rjcbox Member
    PA, USA
    is this gap any different than how air-susp sits in "normal" mode?
  6. jai9001
    jai9001 Member
    Memphis
  7. Dylan
    Dylan Member
    Amsterdam
    Thanks for the pics guys. Was actually curious about this too. I have coils and will receive my 21" turbines soon :)
    Love the coils except for the missing buttons on the interface ;)
  8. Newscutter
    Newscutter Member
    Wexford, Pennsylvania, United States
    At least we're not cursed with the plastic blanks of "regular" cars!
  9. rjcbox
    rjcbox Member
    PA, USA
    "regular" cars are so last century
  10. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    Now if you do 21s then lower your coils............
  11. DingDingDao
    DingDingDao Member
    Orange County, CA
    lolachampcar, I read through the suspension megathread. If I understand correctly, achieving the look you have here is the result of swapping the coil dampers with the air suspension dampers and using the existing coil springs--is this correct? Are there any major modifications required, or is it a straightforward swap?
  12. lolachampcar
    WPB Florida
    I started with P+ (with mandatory air).
    Purchase a set of coil damper assemblies (would be much cheaper to buy them off a total as you do not need the dampers themselves and the rest is hard to damage in a wreck)
    Pull air suspension, remove air springs and have several lower spring perch c-clip grooves cut by your local machine shop on a lathe using a clip grooving tool (very common operation). I went for three in 1/4" increments.
    Disassemble coil units and transfer lower perch, spring, upper perch and all spring isolation bushings to the air dampers.
    Put air dampers with coil springs back on the car.
    Note that it takes a few weeks for the car to finalize on its ride height. I suggest you start 1/4" higher than where you want to end up.
    There are shock dyno plots for coil, standard air and P+ air dampers on the page you referenced.
