T-Will
I can't edit my post above and hotlinks expired, fixed links:
Training chassis at Fremont
Model 3 getting some serious body work at Fremont.
First photos of a FSD Model 3 (without the steering wheel)!
TSportline will be offering a 19" Silver Turbine for the 3 which would look incredible with the Midnight SilverThanks for the pictures, finally we get a good look at a midnight silver (which is my favorite among the available colors) with the Aero wheels. Unfortunately it doesn't look good at all IMO.Gives the car a drab and cheap look. Tesla really needs to offer an alternative 18" wheel in a brighter color.
Any idea how much they would be?
19" TSportline Turbines for Model S are currently available at $425 a piece. If the offsets are similar they could very well use the same rim.Any idea how much they would be?
I like these pictures because I currently drive a VW Golf TDI, so it gives me a really good comparison on size. It's about the size I thought it would be,
True, but the 19" tires that have been showing up on the RC's are not well rated. I genuinely feel you're better off taking the 18" rims (I would keep them for Winter use) and invest those funds in a really good Summer tire/rim package.Keep in mind the cost of the tires alone will probably run you $750. The $1500 isn't a bad deal on the 19" wheels.
Probably 19". Could be 18" but don't think they would clear the brake calipers. For racing application, typically go with smaller diameter wheels to reduce not only the unsprung mass but rotational mass as well.While that render does look nice. The wheels look gigantic and heavy. Not what you want if you want max range out of the battery. Not to mention bending the wheels when you encounter a pothole.
Take a look at this. I like this. How big do you think those wheels are?
They are in fact 18's. Race rubber, as far as I know, only come as big as 18". Yes, even the world challenge series run on 18's. Everything runs on 18's.
Yes, you're correct. You want to have the minimum amount of unsprung weight. So you want the wheels to just barely clear the brake calipers.
18's is what the model 3 comes with. And that's what I'll run when I do place my order.![]()
I'm going back and forth on it myself. I completely agree that there's no reason to run 19"s other than cosmetic ones. Tires cost more, ride is rougher, risk of pothole damage and curb scrapes is much worse.
I would potentially take the 18"s that the car ships with and convert them into winter tire setup and possibly get some other 18"s to swap the factory rubber to.
That's exactly what my plan is. I'll leave the 18's that come with the car as my winter setup. And get some lighter weight aesthetically pleasing 18's for my summer setup.![]()
Or, if you don't mind how the 18s look without the cover, just buy another pair off someone who hates then.
If that's too rich Tirerack has Model S 20" versions (20 x 9" or 20 x 10") available in the $239-249 range (again, depending on the offset); but prices will most likely be similar for Model 3
