I barely clear with the car on very high. No chance of lowering at all if I want to even go through some areas at more than 1 mph.
Not that fun
Wow. Take some photos. I thought roads here couldn’t get worse but apparently I’m pretty fortunate.I barely clear with the car on very high. No chance of lowering at all if I want to even go through some areas at more than 1 mph.
I'll see if I can get some photos to give you an idea. I just drove all over the LA metro area the past 2 weeks and didn't see anything like I deal with in my area. I was as far north as Santa Barbara down to the OC and east as far as Inland Empire. I think we drove close to 1k miles where there. I think they use some of the roads like culverts or drainage ditches. While there are some areas that are due to tire wear, most of this looks intentional.Wow. Take some photos. I thought roads here couldn’t get worse but apparently I’m pretty fortunate.
You may actually benefit from finding a set of the older N2itive links that allowed a suspension raise over stock.I'll see if I can get some photos to give you an idea. I just drove all over the LA metro area the past 2 weeks and didn't see anything like I deal with in my area. I was as far north as Santa Barbara down to the OC and east as far as Inland Empire. I think we drove close to 1k miles where there. I think they use some of the roads like culverts or drainage ditches. While there are some areas that are due to tire wear, most of this looks intentional.
The first day I drove my S out of the house, the same way I drove my Y, the nose of the S slammed into to the opposing side of one these steep approach/departure events that the car literally almost came to a stop. The entire car shook from the impact. The Y cleared all the time but I had no idea how much it actually cleared. I immediately set the suspension on very high and told it to remember.
All was good for a while until the car "forget" to raise itself and I repeated the nose dive into the upraised side of the road. Now every time I get in the car, part of my preflight checklist is to check the suspension is in the very high mode when leaving the house. I also double-check when coming home if I return the way I normally leave.
Hmm. I didn’t know that existed.You may actually benefit from finding a set of the older N2itive links that allowed a suspension raise over stock.
But be careful about raising too much. The front plastic skid plate isn’t flat to the ground. It’s sort of raised in the front and that causes lift in the front.
Been lurking and read 30pgs of this thread and will add my experience and pictures too...
I don't even have a Plaid, just a Long Range 2022 Model S on 22" stock arachnids. I also drive smooth and slow in Chill mode. Never used "Low" suspension setting because I would scrape my driveway if I do that.
Like most of you, I am very OCD about tire pressure and tire wear so I check it all the time and noticed at 14-15k on stock tires that the rear tires were leaking air.
View attachment 961738View attachment 961739
Please send these pictures as part of a recall input here--Michelin and Tesla need to get these tires off the road before someone gets hurt:Been lurking and read 30pgs of this thread and will add my experience and pictures too...
Yes, toe has a bigger effect than camber, with regards to tire wear. That's why it's best to have an indy shop do an alignment in the "low" setting.When you go over 70mph, the car automatically goes into the low setting, and when you get below 70mph, the car automatically raises back to medium.
I think most of us here now agree it's mostly because of too much toe out, not camber. But, the excessive camber does exacerbate the toe wear.
You can message Macboost on Facebook to help you out. He had me use a heavy duty screw driver as a pry bar. Stuck it in the top side of the rotor and pulled with full body weight. Had a second person work the shim in place. It took a few tries and I was concerned that I was going to break something. But working with Macboost I pulled harder and harder until I got it worked out. Second side was easier.I tried other shims. I loosened the bolts then used a 3ft pry bar between the lower control arm and the car body to get the leverage needed to pull down so the upper arm then comes away from the mounting point to create enough room to slide the shims in.
I cut the shim connecting bar and make 2 pieces then installed it.For those that installed the Macboost... any tips on how to get a gap to slide in the shim? I removed the bolts, but was too tight to push down the rotor to get that gap for the shim. Thx!
If referring to the Macsboost shims, "gently" use a prybar or very big screwdriver to make some room after you have loosened everything up a bit. Reach out to Macsboost as well, they have been responsive to me in the past.Having the same problem
