HighPotential
FWIW, the one time I used the classic PS4 (non-Tesla spec) 21" Michelins, they did NOT come apart and lasted 16,000 miles. Coincidence? Not sure.
If my alignment was off, such as the camber, wouldn’t the inner tread or sidewall show excessive wear? As you can see in the pics, there is no excessive wear. The tread simply separated from the sidewall. As you can also see by the treadwear at 15,000 miles, I don’t drive this car hard at all. I have only floored it twice. I drive it like an old lady.
It's definitely a tire failure, but due to a bad alignment and not because of a tire defect.I sit 45 mins from home waiting on AAA because telsa cant get to it until the morning.. same situation. 15,329 miles and even wear but full separation. This seems to be a tire failure for sure.
21” on MS plaid 2023
Yes, please submit photographs AND file a warranty claim with Michelin (Discount Tire is a pretty good supplier for replacement OEM tires BTW).I sit 45 mins from home waiting on AAA because telsa cant get to it until the morning.. same situation. 15,329 miles and even wear but full separation. This seems to be a tire failure for sure.
For the 59th time, the SIDEWALL tears away from the tread, eventually leading to a nearly impossible to notice pending tire failure with ONLY the OEM 21” Michelin tire mounted on the Plaid MS…and NOT the 19” OEM Pirelli tire.When you launch you are compressing the rear and adding -2ish degrees of additional camber. If you start with over -2 then combined with the stiff short sidewalls you gat crazy tire wear. The toe also changes but I'm not sure if it is in or out during compression. Whatever direction it is you should set it to the other end of the factory spec so it's near zero during a launch or hard cornering.
No. When I switched to the 305 NF0 Pirelli rears I chalked them to check this. The Pirellis are close to 1" wider than the OEM PS4S. The PS4S is on the bottom and NF0 Pirelli on top for comparison. If these don't rub, there is absolutely no way the PS4S are.Could the inner eage be rubbing on something?
That's a lot of meat! They fit on the OEM 21" rims? And don't delaminate the way the Michelins do?No. When I switched to the 305 NF0 Pirelli rears I chalked them to check this. The Pirellis are close to 1" wider than the OEM PS4S. The PS4S is on the bottom and NF0 Pirelli on top for comparison. If these don't rub, there is absolutely no way the PS4S are.
Yes, they fit the oem wheels. This is how they look on one of my sets of wheels, these are OEM spec - 10.5x21 45et They fill it in to the perfect size.That's a lot of meat! They fit on the OEM 21" rims? And don't delaminate the way the Michelins do?
