A vehicle's kinetic energy, during deceleration, is transformed into "heat" (thermal energy), without regard to its design, rotor/pad size, efficiency.
Therefore a larger (rotor/pad) & better designed (more efficient) brake system would have a larger thermal capacity (heat sink) and can "absorb" more heat, and "dissipate" heat faster so this vehicle can run at a lower braking temperature vs. the one running with a smaller brake and less efficient system at higher temperature which can quickly lead to brake failure.
For the same kinetic energy (1/2MV^2) ie same vehicle mass and speed; Brake (size & system) = Braking temperature.
