Under high speed braking that the front end was getting a little shaky and did an inspection. Noticed that the tension arm bushings on both sides were torn, so I ordered the MPP sphericals to do a replacement. When they were swapping the arms today, seen that one of the compression arm bushings was torn, and the other was starting to get stressed/about to start tearing as well.
If you drive your car hard and it's a little wanky when you're doing heavy braking or coming into a corner hard, I would highly recommend to pop the wheel off and look at your tension arm bushings.
And the only current solution:
