I had that on my October 2018 build. I had a couple things to address and a mobile ranger came out and fixed them while I was at work. No problems since.
I had the same piece on the passenger side replaced by a Mobile tech. I compared the rear side of the replacement piece with the rear of the original piece, they were slightly different. I suspect Tesla realized there was an issue and redesigned the piece.I had that on my October 2018 build. I had a couple things to address and a mobile ranger came out and fixed them while I was at work. No problems since.
There are other threads on this topic.
That is the only issue I have had with my Model 3 in nearly a year and almost 11,000 miles.
Here is a photo of my passenger side piece, viewed from the front, before it was replaced. You can see the gap at the top.
I had a similar gap on the passenger side. Since I suspected it was responsible for some wind noise I heard at a certain speed, I used a small piece of thick double-sided 3M VHB tape to attach the top of the trim piece (slide into the gap before removing the backing). Easier than dealing with Tesla service.
I don't remember exactly which tape I used, but the piece was maybe 1/2 x 2 inches.Is half inch wide 3M VHB good enough? Which one did u use? Thanks.
