AC on, headlights on, music on.... ridiculous that with a car that advertises 256 miles you cannot do 130 and we have to charge daily. We also have an e-golf (38kWh version) with 40k+ on the odometer that pretty much does 100 miles daily (111 advertised) with a few miles left at the end of the day. Also AC and headlights on.
Its possible if your consumption is high.
I believe based on real world tests under ideal conditions (80 mph, DLR on, concrete level road, no wind, no climate) you should consume exactly 3 miles per KwH in a 85D. (333 wh/mi)
I did this for over a 100 miles both ways in NB last summer in my '15 85D.
In 5 k miles road trip, went 130-150 miles between charges, never below 20%, never above 93%.
I could have gone longer but rarely did because charging over 77% rarely makes sense time wise.
If you consumption is way higher than that, could be you have other factors consuming power such as alignment, tires, brakes, or high resistance in the pack.
SMT is useful to see exactly how much power each consumer is using.
Under the conditions shown above, driving power is about 26kw, pumps and other 12v systems maybe 500 watts at most.
You know the 4kw buffer is used for the range calculation, right? So you can't count on that. A 85 pack in fair condition only has 70 KwH from 0 -100%.
That's 35KwH from 25-75%, about 105 miles at 80mph. So I don't think your experience is that far off.
