Charging at JFK. One spot was ICEd by an Escalade Limo and the other by a cab driver. He was chatting with the tech repairing one of the stalls. He moved.
If you click through the pictures to tapatalk, you can get a higher resolution.Do you have a higher resolution version of this picture or other pictures of the open Supercharger Cabinet?
How did you do this?Please note the current, voltage and mi/hr!
It seems that cars built fairly recently are capable of 40 amp charging on 120 volts. To test this, I temporarily wired my 6-50 outlet so one formerly hot side (and it only works if you get the correct side, the UMC shows a red light and will not charge if you pick the incorrect side) went to neutral instead of to the 50A breaker. I have the single charger, built March 2014, 85KWH. Don't try this unless you know what you are doing.
Thanks, Zapped!
This was the route I was most concerned about when ordering the car: ~825km round trip, no charging for 407km at a stretch and no cellular coverage for the majority of that distance! (Pretty much the ends of the earth ) As I predicted, I had no trouble making it the 407km. However, I did have to drive 15 kph under the speed limit in order to do so (RATED range is very optimistic in my experience).
It was oddly relaxing not needing to worry about overtaking anyone on the highway or being held up by slower-moving vehicles. Fortunately, it is a pretty low-traffic highway so I didn't create any massive convoys. Had that been the case, I would have pulled over every so often to relieve the pressure.
Pretty much my only disappointment with the car is just how hard it is to achieve RATED range (IDEAL range isn't even on the right planet!). Yes, I did a max charge and pre-heated the cabin before starting off. Didn't make much difference.
NOLA_Mike, that car in the post above is absolutely gorgeous.
