Pothole > Blow out > Bottomed out > Bummed out
Discussion in 'Model S: Interior & Exterior' started by NikeWings, Sep 2, 2018.
  1. NikeWings
    NikeWings Active Member
    Snagged a massive pot hole, :eek: blew two tires (FR and RR) and sunk deep knocking the nose out of alignment. It was almost midnight and roadside assistance saved me within 30 minutes with two wheels.
    The SvC returned my wheels with new tires the next day and also realigned the nose perfectly. But I've got this deep gouge in the plastic just under the nose where it banged the road on the way down.
    Any "been there, done that's" around? Grind or sand it down, or replace?
  2. BigCity
    BigCity Member
    Avon, IN
    Damn, now that is a pot hole, I had the same issue about a month ago, both right side tires and both aftermarket rims bent, but didn't get into the body at all. Sorry about your luck. No clue on how to fix it, take it to a body shop and get their opinion, guessing it will depend on how deep the scratches are between fixing and replacing.
  3. ohm-ms
    ohm-ms Member
    Chicago
    The arachnids survived without damage? That’s impressive for a 21” rim. I wonder if a turbine would have fared as well?
  4. nybw51mr42
    nybw51mr42 Member
    Los Angeles, CA
    I was going to ask the same, no damage to the arachnids?
  5. NikeWings
    At the time I was driving Turbines which I love. The front wheel was cracked and scraped badly but the back sustained only a blow out. Arachnids had been sitting in the garage so a good time to finally swap them out.
  6. Tezzie
    Tezzie Member
    Southern California
    OMG! I'm so sorry this happened! After reading this, I put my suspension to the HIGH setting!
    • Funny x 2
  7. ksb467
    ksb467 Member
    Atlanta
    If it is just marking over the paint, try light spray of wd40, followed by light rub of mr clean magic erase pad, only on the impacted area. Good luck
    • Helpful x 2
  8. NikeWings
    Oh I wish. Some of it is deeply gouged from that momentary skid with the decrepit street.
    I made an appointment, might as well get it fixed right although I was very tempted to use my dads electric sander.
    I still might. :D
  9. Tezzie
    Tezzie Member
    Southern California
    Back away from the sander, @ksb467. I like your German SHP, BTW.
  10. Raechris
    Raechris Member
    Boston
    Check the town state - sometimes they have a fund for excessive potholes that cause damage. Theory is it didn’t get that big in a week and should have been patched so their failure to maintain wi reasonable time.
