JRP3
Hyperactive Member
Found a link with detailed replacement instructions and torque specs for the Ford units, (17ft/lbs), which look different than the Tesla unit. Worth noting they say to replace the entire unit if there is separation because of broken bolts, probably concerned with contamination getting inside.
15R01 - Steering Gear Motor Bolt Corrosion - 2013-2015 Ford Fusion & Lincoln MKZ, 2015 Ford Edge
NTSA recall document https://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM477698/RMISC-15V250-1357.pdf
