Other situation:
What is needed to use an MCU board from another Tesla to work in your own ? (given that you can modify the emmc)
Key files
Car equipment
country/region settings like apn
What else ?
(also given that the OS is not too far out)
OK, MCU ist working again.
Pressed reboot on steering wheel...and a fresh 2018.50.6 (same as before, no change) came up.
This is a clean install of an unmodified tesla OS, no changes, no root, no mods except a new chip. Tesla cant complain about that, no secrets here, no security broken. Just a car owner who does the service by himself.
I'm wondering what to do myself at this point with my 2013 P85 with 115k miles. My MCU screen is leaking adhesive pretty badly and it's only a $700 difference between replacing just the screen and the entire MCU. Is the extra money worth it?
Next time you desolder the emmc to replace it in a few more years, root it... I can help you keep the MCU going even with corruption. It's also a good idea because you can disable the insane amount of write logging to /var/log and implement an automatic cooling script to run the AC when the tegra boards go over 70C.
(My MCU "died" last June and has been resurrected 3 times through software hacks)
Sadly, I would say that the extra $700 is worth it unless you know that the MCU was replaced in the last year or two. When you buy a MCU, or touchscreen, out of warranty it comes with a 4-year warranty. So that $700 gets you a new MCU that is guaranteed for 4 more years. (No mileage limit.)
How much does it cost someone to do the replacement of the eMMC? (I know that the parts are cheap, but how much are they paying for a cell phone repair shop to desolder/resolder the chip? And then how many hours of disassembly/reassembly of their car? And how many days of downtime with the back and forth?) And of course you can request to keep your old MCU and you should be able to sell it to recover most, if not all, of that extra $700. (After all it is working just with a bad screen...)
Interesting... what is the warranty period for a screen replaced under warranty at no charge?
More detail please on the software.
