Was going to bring the psi to the recommended 42 today and was surprised to see the reading was much lower than what the car says, is there a way to reset now that I put the air in?
It’s a new compressor thoughWhy do you trust the compressor reading more than the car? I'd try another tire gauge or two before assigning blame.
So? That doesn't mean it is accurate. The sensors on the car are not precision devices, but I highly doubt they are off that far. Spend a little money for an accurate gauge. Something like this;It’s a new compressor though
A high end professional compressor with a pressure gauge calibrated by an independent third party lab? Or a disposable piece of junk $15 compressor from Wal Mart?It’s a new compressor though
Harbor Freight? Did the compressor cost more than a TPMS sensor?Cost?
Looks like the compressor or car is off by 4 psi, compressor said I put in 40 psi car says the tires are 44, so next time I’ll put in 38Why do you trust the compressor reading more than the car? I'd try another tire gauge or two before assigning blame.
It’s one of those portable ones you can plug into an outlet, I like them for road emergencies I can fill up anywhere I am, $50A high end professional compressor with a pressure gauge calibrated by an independent third party lab? Or a disposable piece of junk $15 compressor from Wal Mart?
In my experience (2 Teslas, 2 sets of wheels/tires/TPMS sensors, so 16 TPMS sensors total) the Tesla TPMS tire pressure readings are spot-on.
That's what I do when topping off with my $15 Wal Mart compressor (I keep one in each car).Looks like the compressor or car is off by 4 psi, compressor said I put in 40 psi car says the tires are 44, so next time I’ll put in 38
Good point - it will show "2 hours ago" or something like that if the sensors are asleep. They do stay awake for a few minutes after you stop; I can often double check my readings through the front window as a fill up each tire.The PSI reading in the car is not real time unless you’re driving. Whatever you’re seeing is from your last drive, so that’s one possible reason for the discrepancy.
With 44psi? No.Since I over filled these tires a little at 44 psi when the recommend is 42 I’m not going to blow a tire going down the interstate or anything am I?
The sidewalls will list a max load @ max pressure. Probably @ 51PSI cold, so you're fine.Since I over filled these tires a little at 44 psi when the recommend is 42 I’m not going to blow a tire going down the interstate or anything am I?
