could it be they changed a little thing in the design, and want it covered till fully tested?
I'm guessing the wire running to the hood is for a frunk light?
Edit: Or it might be a cable to the frunk latch (manual release)...think bicycle brake cable. Or it might be for sensors to indicate if the frunk is unlatched.
Or, even more likely, a combination of the 3.
Yes, thanks Disco.
Here are the notable items from VIN48 at Bellevue (exterior)
really bad chrome trim finish was glued to stay on
Could it be a rubber tube to provide washer fluid to the windshield cleaner nozzles?
Unless.... the nozzels are on the hood, just tucked underneath the rear lip to spray up towards the windshield.
Look on the inside trailing edge of the hood, shown on Tommy's picture above, directly below the attachment point for that gray cover under the hood. Black doohickey with a black cord trailing back from it. Could that be a windshield washer nozzle?Unless.... the nozzels are on the hood, just tucked underneath the rear lip to spray up towards the windshield. The tube sure looks more like a fluid tube than a sheathing for cable/wire.
Photoshopped, but that white still looks hot! Even though we googled other white cars and saw similar, those dang panel lines are something I can't unsee
