It seems clear that if you're in the 20-50% range of SOCs (where you'll be if your daily charge level is 50%) you'll probably do better than being in the 60-90% range of SOCs. A lot better? Maybe not. Is there possibly a large element of luck? I still think that's quite possible.
However, it definitely seems like warmer environments are worse, which isn't really a surprise.
Keeping the SOC low as we say, below the about 57% step will basically cut the degradation in half. That should be quite safe to say.
The abolute main part of the people that see issues with higher degradation than they had expected use high SOC, leave the
car charged for time and also mostly live where the temperature have an negative effect.
There is a very few that use high SOC in warmer climate that see very low degradation.
Do we
Know anyone that use low SOC and have lost a lot?
As the research( a lot of research) show very consistent results, its very hard to see
that the same or very closely related cells should behave different mounted in a car.
